So I thought this trail edition 4Runner was a little stiff on washboard roads when stock, but it wasn't gonna stay that way for long... I've got an icon stage 2(650lbs front spring rates) lift kit with the track bar and a perfect alignment afterwards, the route I took with the kdss was to strap the cylinders in place before jacking it up then remove the sway bars, did the lift, put it down and hooked up the sway bars and took the straps off, everything was fine, kdss moves and works like it should, sway bars are level, did the bleed procedure anyway, no air... I do a LOT of Offroading and have years of experience on my own time and in competition.
The thing works great at low speed like 6mph and under, long travel shocks, tires stay on the ground, articulation is great!, I'm running 16psi in the tires but I'm typically going around 15mph on a lot of Stoney or washboard roads and it feels as stiff as a sports car, just like on the street.... my take on this is it needs a much smaller sway bar or the valving in the accumulators needs to be changed for easier movement... I thought it might be the shock valving or spring rate not matching the kdss movement but at higher speeds the shocks work great and I don't want to chance bottoming out if I make a shock valving adjustment + vehicle down time while the shocks are sent out.. Does anybody else with a lift and kdss feel the same rough ride at medium speeds offroad? And are there smaller sway bars out there for kdss? if you have any real experience with your own similar set up please respond.. Thanks
