Opinions/Advice needed
hlpressley
OK guys I need some advice. The front grille and the insert on the hood scoop of my 2000 Runner looks pretty bad. I am assuming the sun just does a number on the plastic painted pieces of these trucks. I would like to address these issues but would rather not have to take the truck to a body shop to have it painted. Have any of you experienced these issues? If so how did you deal with them? I have posted a few pics below to give you an idea of what I am talking about. Thanks in advance for any suggestions.
8ff8017c.jpg~original
9e48fb94.jpg~original
That's plastic for you
You can build it up n hope it lasts again
UV protection is what is needed
I have the same prob -- painted 3x in 10yrs
I got my rattle can OEM paint color base and clear and primer from DuPont auto paint retailer
Begin by sanding the area with a 600-grit sandpaper.
As soon as you can feel that the surface is considerably smoother, switch to a 1000-grit sandpaper and continue sanding until the area is completely free of defects.
Once the sanding is complete, wash with water let dry
The application of a Flexible Primer will help to prevent cracking once the plastic begins to expand in the heat of the sun.
First spray 2 - 3 medium wet coats of Flexible Primer
One hour after the last coat is sprayed; the primer should be dry.
Once dry, sand the primer smooth with 1000-grit sandpaper.
After sanding, wash the area with water let dry
Spray 2 - 3 medium wet coats of basecoat over the primer, waiting 10 minutes between the application of each coat.
One hour after the last coat is sprayed; the basecoat should be dry, dull and ready for clear coat.
Spray 2 - 3 medium wet coats of clear coat over the basecoat, waiting 10 minutes between the application of each coat.
One hour after the last coat is sprayed; the clear coat should be dry.
wayblom
