webshot said:Greg,
Use your stock LED's from your old stock head unit and you will be fine. The voltage difference between the green and orange LED's is approx .1 volts. Since you probably will have the voltage lowered by the lighting knob on the dash, voltage would not be a problem. When I recieve my NAV unit this is the first thing I'm going to do before installing it. I'll let you know how it went.
Jeff
gregtay said:Let me know how this goes. I tried it... i was unable to remove an LED from the original HU without destoying it. Now.. i don;t have a ton of soldering expirance.. so maybe someone that knows what they are doing can do this. Any pointers would be appricated. thx.
webshot said:Yikes! Your iron is tooooooooooo hot! I just use a radiocrap (radioshack) iron with adjustable wattage. works great. I actually already tried it with an old Tacoma radio I had laying around. It is time consuming but is quite easy. I'll let you know how it goes. I should be digging into mine when it arrives in a week.
thanks,
Jeff
gregtay said:Need some help... found a great web site: http://www.eled.com/ I am sure we can get the new LEDs here.. i just don't know which ones to get. Anyone have any ideas? thx.
webshot said:Thanks Greg.
