Ordering axles, a few questions
2StepsAhead
Looking to replace the axles in my 05 4Runner sport...researched a bit and found a bunch of people did the cardone's from rockauto.
Now on part #665235 it says:
W/ or W/O ABS; Front Left; Supplied w/Standard Neoprene Outboard Boot
W/ or W/O ABS; Front Right; Supplied w/Standard Neoprene Outboard Boot
Obviously Im assuming I have to order two, just unclear on the wording cause it says Front Left, Front Right...theres no distinction to ordering one or the other so Im guessing I just add two to the cart and theyre universal right?
Anyone know anything else I should replace while Im in there? Like I saw some people mention seals but didnt see which ones are necessary. Also going to replace my end links cause the boots are torn and the grease came out.
Yep just order two. That's their roundabout way of showing that the P/N works on all configurations regardless of ABS or side.
As far as anything else to replace? Not that I can think of. Just diff fluid. Leave the seals alone if they're not leaking or you could be asking for trouble.
Hope that helps. Good luck.
Check out cvj axles, they of them with extended travel boots if you have lift or are planning on it, they went in no problem and if you get the extended travel boots, they come with the snap ring and dust covers. (Not sure if the ones from rock auto come with that) I'm very happy with them and they look cool too. Pm me if you want to know price but they were very reasonable in my mind.
Jhunt
