Overdrive issue. Tstat, shift solenoid, trans temp sensor????
I went back and watched the video again...
After you finish accelerating to 70 and start to cruise, the RPMs drop to ~2400 (4th, torque converter unlocked), then drop right after that to ~2100 (4th, torque converter locked).
It looks like your truck is hunting between 3rd and 4th/OD, but each time the RPMs drop (back into 4th/OD), you can see the torque converter lock.
It does sound like it could be a control issue (ECU)... Though I still like to think of those problems as rare. Any chance the truck sat unused for long periods of time? That can cause capacitors to go bad...
-Charlie
-Charlie
Regarding the bold above...Actually, yes. He has had it sitting for about 5 months. He would start it every once it a while to keep the battery charged, but he has only put 26k miles on it the last 6 years.
Well, at least that's good the TC is locking correctly.
It was mentioned that 96-98 models do not throw a code for by transmission temperature sensors, correct? Maybe that's my issue, the ECU thinks that the trans is too cold for OD engagement? Does it work like that?
Edit: You're right, I just watched the video again too and it does have the extra little drop once it goes into OD/4, good catch!
ECU can certainly go bad but it is somewhat rare.
A couple years ago I was getting a random pending misfire code even though the engine was running perfectly fine. While I was trying to diagnose a different issue with my transmission, I swapped in a different ECU I got from a junk yard. While it didn't fix my transmission issue, the code has never came back.
Hey,
I'm the guy in the post referenced above. The ECU was bad. Replacing it with a used one fixed the shifting issue. A used one should run you around $85. Swapping it out is easy (though I had a shop do it, long story.) It never threw any codes related to this problem.
Well, looks like my trans fluid is actually fine after all. Blue shop towel had me thinking it was grey -_-
Took a 20 mile drive home today at 70 MPH... Overdrive worked perfectly the whole way. Has to be ECU acting up.
Trans fluid, the dark parts are from the top of the stick
That fluid does need a change, but it probably isn't an emergency. It should look cherry red with no hints of brown when it is good shape.
I actually drove the 4Runner this morning and checks - those are the exact RPMs/speeds for what I described above (4th locked, 3rd, 4 unlocked, 4 locked).
I have a '97 4WD ecu in the garage, but I'm not sure if it is compatible with a '96...
-Charlie
-Charlie
NICE.
Yeah, I plan on doing a trans flush with new filter eventually. I'll probably just start with a drain and fill for now. The main thing is it looks like I don't have a huge issue there and no strawberry milkshake is a plus :D
I'll do some research on the ECU and see if it will work.
Thanks again Charlie
EDIT: oh, also it once again did not have the overdrive issue this morning driving 20 miles to work. I hit 80 at one point and it stayed in OD. I didn't know 3rd gens have magical healing powers?
She’s fixed! Turns out it was in fact the ECU! No more p0505 code and no more overdrive issue! Thanks for all your help fellas! Hopefully this helps someone down the road!
Talyn
