Oversized Spare Tire Mounting Options
ncpinz
Looking for options other than the stock location. Would like to run a full size (oversized) spare. I'm considering just throwing it into the roof rack, but that will put me over 7' which means no garage unless I pull it down.
The hitch mounted spare is a possibility. Would like to know how this fits with towing a trailer which is not often but I could see how this could get annoying.
A rear bumper with swing out spare would be ideal but the cost is a hurdle. Would like more pictures and feedback on ones like CBI. Anyone running something else?
I've been thinking about making a strap mount in the cargo area like some older SUVs did. At least until I get a rear bumper if I ever decide to get off my lazy ass and get a proper sized spare for my 4th gen's current set-up.
V6. I need to try pulling the stock size spare. I bet the whole mechanism is frozen with rust, but I can try putting one of the full size tires in there. I doubt the 285 will fit, and aired down is not typically how I like a spare. A small compressor can cure that though.
The Hitch-Gate looks interesting. Want to see more pictures to see how far off the back it puts the tire. A large gap will look a little hokie.
A 285/17, unless well worn or "small" for its size won't fit without rubbing the panhard if you don't do something about it. I have a new 285 BFG under there that I have stuffed aired down. I did a writeup about it a while back. Basicallt use a ratchet strap to keep it off the panhard bar. I did my first tire rotation last month and put it in service. No ill effects. While having to air up a spare is less than ideal, given the low likelihood of it, I'll take that hassle once in a blue moon.
CoaterZ_FL
