OW 2.5" Install
ArcticEd
I finally got time to install the full OW 2.5" kit and LR UCA's this weekend. Despite a couple of rookie mistakes it was very easy - I'd recommend doing it yourself!
Took me about 7 hours from start to finish being my first suspension work. If I did it again it would probably take 3.5 to 4 hours tops. I didn't take any pics during the install (was focusing on what I was doing) but there are plenty out there from other users. I also forgot about taking before measurements until I already had it on 4 stands :ybrick:. I believe I got a solid 3" in the front and right at 2" in the rear with no CO adjustment.
The front coilover install is pretty much exactly like the OW instructions. My first dumb rookie mistake was to slightly tear the boot on the passenger outer tie rod end ($55 replacement part :bash:). I bought a puller from Sears that has 3 arms instead of two and it doesn't fit. Using a hammer to free the joint is the way to go unless you have a 2-arm puller. I sent Andries a panic e-mail with possibly the dumbest question he's ever gotten before re-attaching the tie rod end, but I'm gonna keep that one to myself :D
The passenger UCA is a bit of a pain to install by yourself because the end of the bolt runs into some of the metal lines in the engine compartment - it would really help to have someone guiding the bolt from above. Once you get it lined up it's easy though. The driver's side has no obstructions. The OW tip sheet says to adjust the camber all the way out for the 2.5" kit - that ended up being a little too much for my truck. The tire was visibly tilted out at the top on the driver's side (easily adjusted). I initially set the caster for +3deg but didn't like the way the steering felt so I backed it to the +2deg position. You can adjust the caster and camber while the truck is on the ground. For reference, the adjusting nut is 1.25".
When installing the rear shocks I initially did the top bolts first & tried to line up the lower bolts by jacking up the axle - couldn't get them to line up that way. I ended up putting the lower bolts on first and then raising the axle to push the top bolts through the mounting point. A ratcheting wrench is a must for those top bolts - preferrably one with a flex head.
The rear springs are easy to do. The factory bottle jack helps to lower the axle and get the new ones in. Apart from that the factory jack is a useless POS.
The biggest problem I had was the swaybar relocation - the swaybar is actually in the back of the truck right now. The holes in the bracket didn't line up precisely with the factory holes in the frame so getting the allen-head screws in was VERY hard (not having the 8mm allen-head socket made it worse). I probably should have stopped to make the holes in the bracket a little larger instead of manhandling them in. The second rookie mistake was when I sheared the head off of one of the bolts while re-attaching the swaybar; hence the lack of a swaybar at the moment. When they say torque it to 30lbs they mean it - don't overtighten them! Working with Andries to get a new relocation bracket set now.
I took it to Firestone after the install to get the lifetime alignment and they got everything into the green. I was very impressed with the service at Firestone - 45mins and I was out of there.
I can't brag on Overland Warehouse's excellent customer service enough - Andries called me within 10 mins of my panic e-mail (didn't even make fun of me :biggrin2:) and I spoke to him 2 more times during the install. VERY responsive.
Overall impressions:
* The truck looks 100% better with the lift - no more nose-down rake.
* Brake-dive is gone and it handles bumps very well. I drove through a powerline easement for a quick offroad test and it's like having a new truck.
* There is a LOT more body roll after the install - almost to a point where it makes me nervous. I can't say this is an issue with the kit at all - I assume it's a combination of: a) Raising the COG on an already tall truck, b) Being used to XREAS before the lift, c) Going 3" higher and still having the stock 20" bicycle tires, d) not having the front swaybar at the moment, and e) still being stock weight all around. I'm guessing the future addition of sliders/skids/bumpers/etc and getting wider wheels will help the feeling that I'm about to roll over.
A big general thanks to everyone on the forum for their write-ups and pictures; I never would have attempted this myself without having lurked about for months. This is a great place to get information and learn about your truck.
I'll get a pic or two up later today!
The body roll should go away with the sway bar installation. That's what sway bars are for. Looking forward to hearing an update afterwards.
Guy
Congrats on doing the installation yourself. I also did mine alone with no prior automotive experience. I spent all day and had no problems.
My kit is the 2.0 and so you are up a little higher than me, but the comment about body roll is alarming. I found just the opposite. I do have KDSS which is noticeably better cornering than non KDSS. Before installing the lift my intuition told me I would get your results - raise the truck and it is going to allow for more body roll. Behind the wheel though I feel I corner much flatter than on the stock suspension and lower height. Perhaps and emergency swerve at 75mph in a lifted truck is not as safe as a non lifted, but in normal driving I find the handling much improved with little to no body roll.
I have a feeling it's mostly about the lack of a sway bar & me getting used to it. I don't know if the suspension is "settling" or I'm just getting used to it, but it feels more "stable" already. I don't think it has anything to do with the kit in any way.
Took a couple of cell phone pics; have to figure out how to embed/attach them
Ok, a couple of poor quality cell pics:
Profile
PostLift.jpg~original
Top of CO & UCA
FrontCO.jpg~original
what the ....... No Pics!
what a tease, nice choice on the lift. Hope you fire out some pics and give a nice couple updates on thoughts of supposed lift ;)
Ha, had to go back and edit this as you threw up pics as i was sipping my beer and writing. thats a good start, thx
Loving the stance, even with the little oem mini donuts
Tires & wheels are the next on the list - trying to stay relatively even on the amount of debt so it will be in stages.
The stock tires are just about shot at 26k miles, and it's not like I burn rubber all the time with the full-time 4wd. Crappiest tires I've ever had.
I'm planning on switching to 17" wheels, just haven't decided on the tire yet.
I'm sure you are right. Once that sway is back on it will feel more normal. I think you can expect a few weeks or longer for full settling, at least I would say it took that long with my 2.0 kit. Welcome to Club Overland :guitar2:
I would slide that camber adjuster all the way out. As Andries pointed out to me when the suspension is at full extension, as when wheeling, the uniball boot will rub the coil and eventually stuff will get in. I am going to adjust mine back out once I get my bumper and need to adjust the coils. Then I'll get everything re-aligned again.
Update:
Got the swaybar back on today. Between that and the wider LT tires any roll I noticed in the beginning is gone. Couldn't be happier with the lift or the tires - it's like putting on a new pair of high quality hiking boots after wearing flip flops :cheers:
If anyone else happens to install one of these lifts it's a good idea to take a dremel to one of the holes in each spacer bracket to make a little extra room for the heads on the allen screws. Completely fixed the problem I had with the first brackets.
delislerebecca
