Owner input on their Rock Sliders
I don't have sliders for the 4Runner yet but based on my experience with the Metaltech sliders on my FZJ80 I'll buy from them again when the time comes. That set was very well built and held up to a lot of abuse.
I would echo [MENTION=80024]STX4Runner[/MENTION]'s comments on the RROs. I have the super sliders, I like the lower profile look, and they have definitely done their job with a couple of dings. I had some issues with the mounting brackets on mine and they did a great job of dealing with it, so i can recommend their customer service too.
Looking to put some rock sliders on my '15 TEP asap.
Reading the forum, there are many choices and am leaning towards Rocky Roads Super Sliders or Meta Techs Trail Edition Sliders.
If you have either of these, can you provide some input:
- likes / dislikes
- installation
- wear (rust / powder-coat / bending)
- Trail Use / Protection / Clearance
- Step usability
If you have a different manufacturer, would be glad to hear your feedback too!
thx!
I love mine... Shrockworks custom steps:
Likes: They look great! They work great as a step, haven't tested them on the trail but don't have doubts. No dislikes really, so far.
Installation wasn't too bad once you find your starting point. If you have an LE, XREAS lines can be tricky... I think the same for KDDS.
No rust yet, but that can be remedied by some touch up paint.
Step usability A+++ .. Here's a pic and a video of my son climbing in:
<iframe width="203" height="360" src="http://www.zenfolio.com/zf/core/embedvideo.aspx?p=29d4d067.10" frameborder="0"></iframe>
I'd like to remove the rocker trim on my LE and get a slider that fills into that empty space without needing TE rocker trim... I know some people have this setup and just wondering my options. Don't really care if it acts as a step or not...
Still have decided on a set but I'm pretty much down to these five (in my rating order so far). Starting on a little aggregate list of the sliders. I still have a lot of "Unknowns" to figure out.
4x4 Labs
- around 70lbs each
- Good step/foot area
- Remove rocker panel and mud flaps on TE
- Possibly High clearance as they tuckin/replace where rockers are
MetalTech
- Unknown weight
- Unknown rocker panel remove/trim/leave alone on TE
- Unknown clearance
BudBuilt Beefy
- around 65lbs each
- Unknown clearance
ShrockWorks
- Unknown weight
- Pretty good step/foot area
- I "think" you leave rocker panel alone on TE
- Unknown clearance
Rocky Road Super Slider
- around 40lbs each
- Not much of a step/foot area
- No removing of rocker panel for TE, possibly trimming of mud flaps
- Possibly Lower clearance as the wrap under/around rocker panel
Since you haven't decided I just thought I would give you my 2 cents worth.
I have the Metal Tech OPOR sliders and installed them about 3 weeks ago. I was torn between those and the Rocky Road super sliders.
-Decent price if you go with bare metal and either paint yourself or have PC'd locally (I had them PC'd)
-Very beefy, about 55lbs each (just a guess based how they feel, I didn't actually weigh them)
-Decent amount of area to step on up front and a decent bump-out at the rear
-Easy to mount up with a hydraulic jack (I mounted both of them in about an hour by myself)
-Fit and finish are great, they mount nice and flush under to the body and rocker area with a very slight upward angle to the step portion
Dislikes:
-None yet, I am happy with my selection.
Thanks 1traildriver.
I think I would have already pulled the trigger on the 4x4labs, but that weight is crazy. Seeing if there is something similar with the high clearance and durability, but shave 20lbs.. so maybe more like 45-50lbs a side.
I have the close fit shrockworks. Amazing. Saved me a couple times already. Subtle looks. Decent step. Don't muddy my pants. Definitely didn't feel all that heavy even though they are beefy.
You are not going to find a set that is both super light and very durable. The reality is that most sliders just work and will be within 20lbs total weight. They are almost all up high enough on the outside to where they are higher than the frame rails.
I would just go with a reputable company that does quality stuff. Can't think of any bad ones mentioned here.
Your armor will take way more hits than your sliders. Be concerned with your lower links and the lower link brackets. Those were the first things I banged up and damaged on the trail. Sliders have taken a few minor hits because it is hard to abuse them until you replace the front bumper ;-)
I have the Rocky Road super Sliders and am happy overall. I had Rocky Road make them a little shorter in the front to clear my mudflaps (No extra charge). I also added 3/8" plates behind where they mount to the frame to push the sliders out a little more for a little bit of becoming a step. Seems to work quite well.I can tell you that after 4 years on the truck even thou powdercoated they became pretty RUSTY when you looked under the car area of the Sliders. I removed them sanded, applied POR 15 and repainted. Now they look like new and with the Por 15 should give me many more years of use. Over all I am very happy with these.
If you don't want to do the sliders that allow you mount without removing the LE trim for clearance issues and don't want to buy TE trim or Shrockworks trim, I think you may be limited to the Randy Ellis Design sliders. A couple people on here have them and they seem to hide the empty space pretty well.
P.S. You could also trim your LE trim to fit as many here have done.
Down to 2 selections
4x4 labs and metaltech.
Both weight about the same. Both have a good step and can be used as a real slider.
The only real difference left that im not sure how to interpret is the removal vs keep of the Trail rocker trim.
I dont have "rocker panels" to deal with like the sr5 and le...
The 4x4 remove the trim and mount flush in that area giving more clearance.
The.metaltech mount below.
Not sure if the clearance diff is useful, a pro or a con...
Thoughts?
Thoughts?
Go out and look at your frame rails, gas tank skid and lower link connectors in the rear and compare it to the rocker height... More clearance is always better offroad, but I doubt removing the trail rocker trim would gain you much considering all those other points are lower. You will have way more issues with the bumpers and undercarriage....
This. However, I still would take 4x4labs over metaltech here. Both are superb but the labs sliders are a bit more protection than the others. Really you'll probably be happy with either. Both are excellent armor.
still no decision - need some pix on a TE/TEP!
Looking for pictures of TRAIL 4runners with their sliders without removing the TRAIL rocker panel.
:photo: :photo:
Looking for pictures of your slider with step (ie 4x4 labs, Metaltech, Budbuilt, etc) that does NOT have SR5/LE body panels, just the TRAIL rocker trim. :D
:photo: :photo:
More specifically, from the side front/rear at slider-eye-level. Trying to understand how it impacts the wheel well, the removal of the "mud flaps" if needed, how the end of the slider is tapered or not, etc.
Thanks again!
:photo: :photo:
:photo: :photo:
Thanks again!
Sorry i saw this post last week and was going to reply sooner but better late than never. So here are some pics of my budbuilt beefy bumpout fulltread powdercoated sliders on my 14 TEP. I think these are all of the pics you were asking for plus some of how they mounted to the frame.
Great timing. My Budbuilts were delivered today. They are the same as yours but they aren't beefy. Thanks for the pictures. I'll be referring to them this weekend when I install the sliders.
