bigskyeric
Hi everyone.. I haven't been on here in a while, which is a good thing because it means my 04 4runner with 209,000 miles hasn't had any issues.
I know the oxygen sensor questions come up often and a few that I read said to check the 'sticky'... but there isn't a sticky (unless I'm blind)
Anyway... here are my questions.
My T4R is throwing a P420 catalyst below threshold code. It deosn't specify which bank it is. I'm using the iPhone app 'engine link' which has been awesome so far.
Most threads I've read say that it is most likely NOT the cat but the sensor 2 oxygen sensors. Both sensors were replaced last year and I used Denso sensors. Engine link is reading both sensors as running between 0.2 to 0.9 voltage. Bank 1 sensor 2 averages about 0.1 lower voltage than bank 2 but I figure this is due to it's distance being further away from the engine.
Both Bank 1 sensor 1 and bank 2 sensor 1 are not reading anything and appear to be dead. So I figured this is the culprit. But from my research, sensor 1 has nothing to do with reading the cats because they're before the cat.
To make this even more confusing, what I thought was the oxgen sensors (bank 1 and 2 sensor 1) appears to be the air/fuel mixture sensor according to this diagram. http://www.toyota-4runner.org/maintenance-detailing/52109-h02-sensor-bank-1-sensor-2-p0136-code.html (leaving me unable to find the oxygen sensors)
But then this diagram says otherwise. http://www.tundrasolutions.com/forums/attachment.php?attachmentid=43743&d=1247837544
Anyone know which diagram is telling the truth?
I know the easy answer is... replace the sensors since they're obviously dead. But at $100 a piece (even at Rockauto.com) for the denso.......
Thanks in advance for any insight you may have.
-Eric
-Eric
