P0136
coinball
I've been chasing around a P0136 ever since I put on TRD headers and the URD rear 02 sim; is this a common problem? I guess I could put my scanner on the truck and drive around to see what the voltage is doing to cause the CEL, but I'm lazy.
It was really bad when I had my volant CAI on the truck; it was significantly reduced when reverted to the deckplate mod and K&N filter. It seems to happen when running the A/C and driving aggressively, going hard on the throttle and jumping off the gas onto the brakes seems to really bring out the CEL.
The O2 and A/F sensor are both new Denso's about ~40k miles ago; so I'd be surprised if the problem was the sensors. I don't see/hear any obvious exhaust leaks so I'm at a bit of loss...
... I guess I could put my scanner on the truck and drive around to see what the voltage is doing to cause the CEL, but I'm lazy.
Well we sure wouldn't want you to actually do anything, so why not just replace the sensor that the P0136 code is telling you to replace?
AlaskaRuss
