P0171 Question
kaloman
Wassup everyone,
This is my first real post and I appreciate all the help! I recently went to a dealership, which diagnosed a P0171 bad O2 sensor. So I replaced it. The check engine light went away and came back a week later. I ran the diagnostics and it again said P0171, but now system lean, bank 1. I've been reading that this may be attributed to a dirty or bad MAF sensor, so I took it out and sprayed MAF sensor cleaner on the wires and bulb. I gave it a good wash. Reinstalled, and within a few hours, the light was back on again. Could this be a bad MAF sensor which needs to be replaced? My 2000 4runner has 143,000 miles and I do not believe I've ever replaced the MAF sensor.
Also, when I was cleaning it, I noticed that the temperature bulb was extremely dark and didn't at all get clearer or translucent when spraying. I wasn't sure if this was normal. The other two wires appeared to look cleaner, but heck, I'm thinking it just may be the end of it's useful life.
Kaloman
Wassup everyone,
Kaloman
Did you get the wires on the inside of the MAF clean and not just the wires/bulb thing on the outside? A lot of people make the mistake of thinking it's just the outside part you clean so I wanted to make sure you cleaned the right part first.
Thanks for the help fellas.
fightman80, I checked out your link and it put me over the edge to just go ahead and buy another MAF. Hopefully everything works out.
kball, I made sure to not only spray the bulb, but also the two hot wires inside the housing.
Thanks!
O2 Sensor replaced - Check!
MAF Sensor replaced - Check!
P0171 Engine Light back on - Check!
Okay, so I just replaced the MAF last night and this morning after driving about 15 miles and right after filling up gas, the infamous CEL is back on again and pulling up the same P0171 (System too lean - Bank 1) code. I'm not sure what to do next. Do I need to drive the thing a little longer for the computer to relearn? I just erased the code a few minutes ago.
Any ideas? Man I hope it's not a fuel issue.
Thanks!!
Kalo
aw motherfugker that sucks man i have p0171 too check all your vacuum lines because the lines are after the maf so if there is a leak and the computer aka maf doesnt know i will throw a code doesnt matter what you replace
t4r4life - I will check the hoses! At 143K miles, I don't think it was a bad thing though to change out the MAF and O2 sensors. Call it preventative and predictive maintenance. haha
Okay, so here's an update. So I changed the hoses and the light still came back on. I finally found out that I had a dirty throttle body. So I bought some cleaner, sprayed the bejeezus out of it and cleared the code. Code stayed off!
Now here's the kicker, the CEL (P0171) comes on only after I fill up a full tank of gas. Once I burn through a gallon or two, it goes off. Cycle repeats itself on the next fill up.
How do you diagnose this? Dirty fuel filter? Bad pump?
5th Gen 4Runner is looking pretty good haha
You may have the same problem as alot of 3rd gen. owners like myself but when I fuel up and like others they always get as much fuel in as possible and this cause the excess fuel to leak into the carcoal/evap canister throwing a code so next time you go to the pump once its kicks you off from fueling leave it and see if the CEL comes on if not then thats what it is doing and if it does then IDK...but another thing about over fueling is it will eventually damage your EVAP canister and thats a 480 dollar part just FYI
Damn, just filled up today and pressed it one additional time after stoppage. I gotta check to see if there is a way to test the evap canister.
Thanks!
Thanks!
I dont have a diagram or a write up on how to do it but my EVAP canister is bad but I know my sensor for it are good if that makes sense. I checked the switches for it under my hood I believe there is 2. I had my buddy help with this but you could prolly do it yourself. Take one of the sensor outs and get a piece of speaker wire or any wire of that type put it on the positive battery post and the other end on the valve and blow into it and if air goes thru then its good. Take the wire off of it and try to blow through it and if no air flow then your switch is working perfect do the same to the other switch and if both are good then its more likely the canister by the gas tank. If you want to see if the Canister is bad you can take it to the dealership or any shop probably and do a smog test on it and see if its bad. I hope this helps and doesn't confuse you to much and ANYONE can feel free to elaborate more or tell me if its completly wrong.
Selecting a replica watch on the internet could possibly be a gratifying and easy purchasing expertise if entered cautiously and understanding any potential problems or risks. Réplique Montres Buying on the web is not usually high-risk as soon as you understand the strategy to go about it safely and securely, but for your unsuspecting and naive customer, buying on the internet may be a process filled with danger.
Warranties
Usually, unethical on the internet merchants will not respect their assure pledges therefore the most effective approach to purchasing any replica view is from a reliable supplier. This may well imply a relatively higher cost however you may also obtain the reassurance understanding your buy and guarantee is honored from the vendor.
Getting from an Auction
Whenever you encounter your dream view on an on the web auction site there are many things you need to do prior to going crazy and getting it immediately. Remember that all you need to go by in evaluating the view are:
Your expertise with the view in issue.
The photos the seller has posted.
The description in the watch she or he has supplied.
The reputation in the vendor (feedback proportion).
Prior to you purchase any view on the internet make certain you're comfortable and assured in Every 1 of those areas. Do not buy some thing having a fantastic description and pictures when the seller has a reduced feedback percentage. If the images in the view are from the manufacturers' internet internet site or stock photos, be very wary of the seller. Stability all of the locations with common feeling just before you obtain.
Your Information
This guide's goal will likely be to enhance your common comprehending and awareness of replica watches within the present marketplace. However, it is also a good idea to study and find out as significantly when you probably can in regards towards the authentic view prior to acquiring. Make an work to determine the genuine watch and handle it. Despite the fact that you might only have photographs to judge the replica watch, your personal individual encounters with the real watch will help in your final decision.
Additionally, there are lots of on the internet resources in aiding you evaluate a particular view and its features and functions. Be conscious in the manufacturer's website and evaluation and scan every bit of info that is to the web site. Most businesses although have minimal data and facts on-line, seeming to feel it's more beneficial to possess a showy dynamic website than 1 which offers a listing of functions and data.
Nevertheless these sites are excellent resources to obtain a strong idea of the distinct kinds of every single product. Also numerous images in the manufacturer's web web site are stolen and reused as actual product photos in auctions. By being familiar using the stock images, you'll know what to try to find if you purchase a replica view.
The Images
It is usually crucial to own good pictures offered of a view you're looking to obtain. It states the seller is being open and sincere about the sale by offering you having a distinct picture for inspection, and much more importantly the vendor is not attempting to cover something by posting fuzzy images that obscure particulars.
Inadequate images present you no help and really damage the possible sale by withholding details. When you have any doubts about a view because of the pictures tell the seller that you are interested in the product but you'd like to determine some further images.
Be conscious that some dishonest men and women will use photos of other replica watches and present them as their own. When this happens you're in no way sure of what you will really get in the transaction.When the pictures are very poor, fake or poor good quality on an auction, it's normally a indication of some sort of deception. Nonetheless, in the event the view is what you need ask the vendor for extra pictures to help you gather the information you need.
The Description
The description the vendor gives is your only supply of detailed details concerning the view in query. You ought to inquire about comprehensive information about the situation in the watch, as well as specifically what comes using the purchase. Details are a superb indicator that the vendor understands what he has and finds it important that any possible purchaser has enough info to create an knowledgeable decision.
When inquiring about additional details not inside the description, several disrespectable sellers will attempt to make excuses that they're not sure. This generally points towards the fact that they are fully aware the replica view is actually a low cost high quality one instead of a well-made quality 1, hoping you will get their bait and purchase it anyway.
The Popularity
Ultimately, it all arrives down to how nicely you are able to believe in one other celebration inside the transaction. After all, you're purchasing a item that you simply have in no way observed from a total stranger. You need to set up a specific amount of believe in with that individual to decrease your general risk in the buy.
Most auction internet sites provide a approach of suggestions that offers a rating for the seller's previous transactions. This allows other consumers to offer the thumbs up or down to the way the seller dealt with the transaction and the high quality in the items in comparison to the description. Greater ratings and sellers with storefronts are good indications which the person will only cheat himself by trying to swindle you; whereas, if a seller has a reduced rating, he has small to shed if you're displeased using the buy.
The Transaction
Prior to you get or bid on a replica watch search carefully in the particulars in the listing by itself. It will show the payment methods accepted, as well as the delivery prices and expenses. Make certain you do not use a approach that allows the seller to get your cash and give you no way out afterwards in case you are unhappy. If probable spend by charge card or Paypal, which gives you some alternatives later on if there's any difficulty.
Buying from a vendor inside the same country is the easiest approach to deal with a transaction as delivery is much simpler, whereas acquiring from a foreign vendor involves greater shipping expenses and greater threat like customs, etc. But when there is no other option, at least persist around the view being delivered a trusted carrier such as FedEx that could provide a tracking number and insurance.
It's Right here
As soon as you receive your replica watch, open the package deal cautiously and inspect the goods, producing positive you acquired what you compensated for. Look at the view in detail; inspect the situation again and dial. Do all of the capabilities work properly? montres suisses à bas prix Does it wind well and does the crown screw down tightly?
With any luck the view is that which you desired and you'll be able to depart optimistic feedback or reviews for the vendor or his internet site. But for those who have a difficulty with the view or even the transaction, immediately get in touch with the seller and politely explain what the issue is. It could just be an sincere error on their part and some thing they're going to attempt to repair or change.
Nina Hirasawa is really a buying and buyer support expert. She is definitely an established writer for two purchasing guidebook magazines, and specializes in shopping, yoga, Web advertising, and replica watches. She runs a number of online retail stores specializing in Swiss replica watches and presently has an Seo services web site in advancement.
WTF is this it has nothing to do with the topic at hand
Admin, please delete this Topix by weimingqq it is a spam.
@weimingqq if you are trying to spam on this forum take your post and posted somewhere else not here in the T4R.org
so typical, no followup.
this is got me frustrated too. I've had a fuel injector or multiple ones, leaking fuel due to bad O-rings. One came apart when I pulled the fuel rail which I think was the main culprit. To not take any chances, I bought a remanufactured one and replaced all 3 O-rings. Truck is running much better and fuel smell is gone :trophy: but of course the dreaded CEL came on. Pulled this same code and the moron at Autoparts tried telling me it has to be one of my O-2 sensors despite it reading system lean.
At the same time I did the o-rings I replaced my PCV valve n grommet and the Air filter and I noticed that original air filter I was replacing was in backwards.:mad2::mad2::mad2:....so now I can only imagine how filthy the MAF and throttle body are. Truck has 188,000 miles n i just got it in January. My plan is to clean the MAF n Throttle body tomorrow, resit the EFI n battery. I'm hoping that this is enough and that there is nothing else! When I have more time I'm going to sea foam, oil change, fuel filter, spark plugs n wires and finally prey that I don't end up with this dreaded CEL!
What do you think is causing your code?
