P0171 - System Too Lean Bank 1
At least with the preliminary data, not a vacuum leak and probably not a direct fuel problem. Most likely an aging sensor. Post the new data once you have it.
You need to repost the results after the engine is fully warmed up. Include rpm and TPS. Try and switch your readings to American measurements if you can.
This better? What's it tell ya?
...again, thanks in advance!
Here is mine from this afternoon after a drive to the grocery store and back, sorry it’s upside down.
I had this code right after I half-assed cleaning my MAF sensor. What I did was fully clean it and reset the ECU and it hasn't come back (that was months and a couple thousand kms ago). Not saying that it isn't the O2 sensor, by any means, but you may as well try and clean the MAF to see if that does anything before replacing parts. Probably best to clean TB/IAC while you're in there, too. good luck!
I would save your pennies and get both, but definitely replace the upstream if money is tight.
Ever cleaned the TB/IAC?
I will on the O2s... I do some seafoam cleaning of the TB and I spray cleaner into the IAC when I am cleaning the MAF (the right brass screw is removed with a vice grip as the first attempted removal found her not budging, haha). I haven't paid an overwhelming amount of attention to the IAC, save I just insure she moves easily.
I pull the lower idle assist hose off the IAC and spray in there until no black chunks are visible in the inlet to it.
Hi everybody, I'm new to the forum trying to diagnose a P0171 code on my (new to me) '01 SR5.
So far, I've solved my P1135 & P0420 codes by replacing both O2 sensors with Denso.
For the unsolved P0171, I tried cleaning my MAF but the code returned. My next task was gonna be to check for a vacuum leak. Not sure if there's any common things I'm missing or could try? Thanks in advance for any input.
i recently bought the truck and the dealer didn't disclose multiple check engine codes so I'm hoping this is an easy fix :)
One toyota website suggests vacuum leaks like you're saying, but it also goes on to say that it could be a leak in the PCV hoses or even the valve itself.
If you replace the PCV valve, make sure you get a new grommet to go with it and take your time. Get it from Toyota, they are inexpensive. Have needle nose pliers on hand in case it begins to crumble and you get bits down
in the hole it comes out of.
Sent from my SM-S908U using Tapatalk
Mechanic didn't detect a vacuum leak. Changed the MAF (new Delphi) and also replaced the PCV valve+ gasket.
CEL stayed off for about 100 miles and then popped back on. P0171. O2 sensors are new as well. Any other suggestions? I'll try to get a smoke test done soon if that's my only option besides the fuel filter..
matisgugle
