P0306 code quick help
razerface
Member
I have a miss that i narrowed down to cylinder 6 missfire by code p0306.
I changed plugs
I tested wire
I changed coil
That leaves the injector. I want to get to dealer and get parts to fix this weekend. Can anyone tell me what i have to buy besides the injector? Anything i will need to watch out for? Just tear off the top and replace?
Just the o ring for the injector.
6 cyl, thAt is closest to radiator on driver's side I believe.
Plenums, throttle body should come off for driver side injectors, to get to fuel rail.
May as well do plenum gaskets while you're in there. I wouldn't re use them, anyway.
I did 5 and cleaned 3 last year, now 1 just went. I'm about to do all six new and rebuild the ones I take out, even the newer #5 injector. Going to keep them as spares
I would just do all 6 if I were you.
My bad on cyl six location
..long day,
See my thread about eBay injectors. Just leave those eBay sellers alone when it comes to this stuff... I got burned. Seller noted AISIN as description then updated after to indicate another brand.
I find rebuilt on ebay $77 for all 6. Anyone ever use these cheap rebuilts?
I am happy to buy parts on eBay, and has always been fine, but just this week got burned on six injectors and a tps. Counterfeit and misrepresented respectively.
Today I swapped in a GB reman. There about 50 bucks each or less on rock auto (53 CAD)
Vspro9
