p0418 secondary air relay
lmoody003
Hey I have a question about a DTC p0418 secondary air system malfuction on relay A circuit.
I have installed the AIP bypass module that gets rid of other Secondary Air pump failure codes. My t4r is now throwing the p0418 code and I am having trouble finding precise info. I have looked for a relay to change but I have looked everywhere and Toyota doesn't map or call for this to be a relay at all. I have also looked at "smog relay" or something genetical similar but no luck.
Any Ideas?
Its showing my check engine light, vac trac off light on the dash.
Answer?
Has this been fixed? I see no follow up. I have 2005 runner v8 installed bypass got rid of codes except 0418. Did you figure out a way to clear this code?
