P0420 & P0430 Codes
olalekanbabs
Hi everyone, am new here.
My car details; 2005 4runner SRS5 4WD V8 4.7L 84,570 miles, presently VSL trac/trac off & maintenance light came up on dash board. I checked the codes and got P0420 & P0430 Codes, I was thinking of changing the four o2 sensors but a mechanic recommends that I should try catalyst bypass.
Also the fuel consumption is extremely bad.
the codes are indicating that you have insufficient O2 sensor readings..
the O2 sensor on bank one up stream is reading the same as the 02 sensor down stream which is telling the computer that the catalytic converter isnt working properly..
it could be the catalytic converters, however if theres any exhaust leaks from your manifolds before the catalytic converters this will cause a faulty reading as well.
check for exhaust leaks first.. with the engin running and the hood up listen for ticking noises comeing from the left of right side of the engine..
if no exhaust leaks are present check the voltage readings of the 02 sensors to make sure there functioning properly..
If the 02 sensors check out and theres no exhaust leaks then you'll need to replace the catalytic converters...
hope this helps..
you can also google the trouble codes and get a generic idea of what the codes are pertaining to.
the p0420 is you driver side 02 sensor/ catalytic converter (bank 1)
the p0430 is the passenger side.. (bank 2)
you havn't by chance gotten ahold of leaded fuel by chance that can cause this issue as well. or running really bad gas as well.
Am not based in US, am sure fuel being sold here is not leaded fuel.
I will also check for exhaust leaks and keep you posted.
Not sure what country you're in, but I think we have an 8 year emissions warranty in the US. You might see if there is some similar regulation in your country.
My major concern are the codes and the car fuel consumption is extremely bad.
I did checked the exhaust yesterday, everything seems fine.
Yes.
You need the simulator to "fool" the car into thinking all is well.
What country are you in? Crappy gas?
Am in Nigeria, can you enlighten me more concerning catalyst bypass. I hope it wont have affect the performance of the car in the long run.
Fuel consumption is terrible at the moment.
I was able to use Actron CP9580 to check the car, I know this is tending towards replacing the CAT's, can anyone explain better what the data below means;
2005 Toyota 4-Runner 4.7
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon ok
Sec Air System ok
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr n/a
EGR System Mon n/a
This Drive Cycle
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon n/a
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon n/a
Oxygen Sens Htr n/a
EGR System Mon n/a
DTCs (Codes)
P0420 MOD $00
Catalyst System Efficiency Below
Threshold Bank 1
PENDING
TOP REPORTED FIX
1-Replaced Catalytic
Converter
FREQ REPORTED FIX
1-Replaced Oxygen
(O2) Sensor
ALSO REPORTED FIX
Converter Gasket
P0430 MOD $00
Threshold Bank 2
PENDING
FREQ REPORTED FIX
Converter
State OBD Check
MIL Status OFF
Codes Found 0
Monitors OK 5
Monitors Inc 2
Monitors N/A 4
Record Data
FRAME: -1 TM: -4.6
MIL STATUS Off
ABSLT TPS(%) 19.6
ENG SPEED(RPM) 0
BARO PRS("HG) 29.5
CALC LOAD(%) 0.0
MAF(LB/M) 0.20
COOLANT(°F) 201
IAT(°F) 169
IGN ADV(°) 5.0
SECOND AIR N/A
ST FTRM1(%) 0.0
LT FTRM1(%) 7.0
ST FTRM2(%) 0.0
LT FTRM2(%) 10.9
VEH SPEED(MPH) 0
ABS LOAD(%) 0.0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
REL TPS(%) 0.4
THROT CMD(%) 16.5
ABS TPS B(%) 51.8
ACC POS D(%) 15.7
ACC POS E(%) 31.8
CAT TEMP11(°F) 996
CAT TEMP21(°F) 996
CAT TEMP12(°F) 746
CAT TEMP22(°F) 746
EVAP PURGE(%) 0.0
ABS EVAP VP(H2O)403.2
CMD EQ RAT 0.824
O2S12(V) 0.015
O2S22(V) 0.015
O2S11(V) 4.001
EQ RATIO11 1.000
EQ RATIO21 1.000
O2S21(V) 4.002
MIL TIME(h:m) 00:00
CLR DIST(mi) 26
CLR TIME(h:m) 05:32
CLR TRPS 3
MIL DIST(mi) 0
VPWR(V) 12.226
ENG RUN(m:s) 00:00
OBD2 STAT CA
O2 Monitor Tests
Not Supported by Vehicle
Diag Monitor Tests
O2 Sensor B1S1
Test $8E
MOD $00
MAX 0.000(V)
MEAS 0.000(V)
MIN 0.000(V)
STS OK
Test $91
MOD $00
MAX 0.000(mA)
MEAS 0.000(mA)
MIN 0.000(mA)
STS OK
O2 Sensor B1S2
Min V for Cycle
MOD $00
MAX 0.195(V)
MEAS 0.097(V)
MIN 0.000(V)
STS OK
Max V for Cycle
MOD $00
MAX 1.190(V)
MEAS 0.859(V)
MIN 0.605(V)
STS OK
Test $8F
MOD $00
MAX 2.998
MEAS 0.007
MIN 0.000
STS OK
O2 Sensor B2S1
Test $8E
MOD $00
MAX 0.000(V)
MEAS 0.000(V)
MIN 0.000(V)
STS OK
Test $91
MOD $00
MAX 0.000(mA)
MEAS 0.000(mA)
MIN 0.000(mA)
STS OK
O2 Sensor B2S2
Min V for Cycle
MOD $00
MAX 0.195(V)
MEAS 0.078(V)
MIN 0.000(V)
STS OK
Max V for Cycle
MOD $00
MAX 1.190(V)
MEAS 0.898(V)
MIN 0.605(V)
STS OK
Test $8F
MOD $00
MAX 2.998
MEAS 0.001
MIN 0.000
STS OK
Catalyst B1
Test $A9
MOD $00
MAX 9.994
MEAS 0.005
MIN 0.039
STS LOW
Catalyst B2
Test $A9
MOD $00
MAX 9.994
MEAS 0.005
MIN 0.039
STS LOW
Purge Flow Mon
Test $C9
MOD $00
MAX 4.752(PSI)
MEAS 0.026(PSI)
MIN 0.000(PSI)
STS OK
Test $CA
MOD $00
MAX 4.752(PSI)
MEAS 0.348(PSI)
MIN 0.000(PSI)
STS OK
Test $CB
MOD $00
MAX 4.752(PSI)
MEAS 0.217(PSI)
MIN 0.000(PSI)
STS OK
Test $CD
MOD $00
MAX 4.752(PSI)
MEAS 0.217(PSI)
MIN 0.000(PSI)
STS OK
Test $CE
MOD $00
MAX 4.752(PSI)
MEAS 0.316(PSI)
MIN 0.000(PSI)
STS OK
Test $CF
MOD $00
MAX 4.752(PSI)
MEAS 0.233(PSI)
MIN 0.000(PSI)
STS OK
Test $D0
MOD $00
MAX 4.752(PSI)
MEAS 0.329(PSI)
MIN 0.000(PSI)
STS OK
Test $D1
MOD $00
MAX 4.752(PSI)
MEAS 0.217(PSI)
MIN 0.000(PSI)
STS OK
Test $D4
MOD $00
MAX 4.752(PSI)
MEAS 0.354(PSI)
MIN 0.000(PSI)
STS OK
Test $D5
MOD $00
MAX 4.752(PSI)
MEAS 0.348(PSI)
MIN 0.000(PSI)
STS OK
Test $D7
MOD $00
MAX 4.752(PSI)
MEAS 0.000(PSI)
MIN 0.000(PSI)
STS OK
Sec Air Mon 1
Test $E1
MOD $00
MAX 86.51(LB/M)
MEAS 0.63(LB/M)
MIN 0.27(LB/M)
STS OK
Test $E2
MOD $00
MAX 0.72(PSI)
MEAS 0.02(PSI)
MIN 0.00(PSI)
STS OK
Test $E3
MOD $00
MAX 95.05(PSI)
MEAS 1.14(PSI)
MIN 0.14(PSI)
STS OK
Test $E4
MOD $00
MAX 2.90(PSI)
MEAS 0.04(PSI)
MIN 0.00(PSI)
STS OK
Test $E5
MOD $00
MAX 95.05(PSI)
MEAS 7.59(PSI)
MIN 2.35(PSI)
STS OK
Test $E6
MOD $00
MAX 2.90(PSI)
MEAS 0.03(PSI)
MIN 0.00(PSI)
STS OK
Test $E7
MOD $00
MAX 95.05(PSI)
MEAS 2.01(PSI)
MIN 0.75(PSI)
STS OK
Test $E8
MOD $00
MAX 95.05(PSI)
MEAS 0.31(PSI)
MIN 0.23(PSI)
STS OK
Test $E9
MOD $00
MAX 0.00(PSI)
MEAS 0.00(PSI)
MIN 0.00(PSI)
STS OK
Misfire Data
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 1
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 2
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 3
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 4
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 5
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 6
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 7
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 8
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Monitor $E1
Test $E8
MOD $00
MAX 5930.1(°F)
MEAS 167.0(°F)
MIN 167.0(°F)
STS OK
Vehicle Information
VIN
#1 MOD $00: JTEBT14R058027606
CVN
#1 MOD $00: D1 9B F0 A1
CAL ID
#1 MOD $00: 33532200
IPT
#1 MOD $00:
OBD Mon Cond 5
Ignition Cycles 31
Cat Comp Bank1 7
Cat Cond Bank1 5
Cat Comp Bank2 7
Cat Cond Bank2 5
O2 Comp Bank1 2
O2 Cond Bank1 5
O2 Comp Bank2 2
O2 Cond Bank2 5
EGR Mon Comp Not Available
EGR Mon Cond 5
AIR Mon Comp 9
AIR Mon Cond 1
EVAP Mon Comp 2
EVAP Mon Cond 1
Also how many Cat's does the car have?
Record Data
FRAME: -1 TM: -4.6
MIL STATUS Off
ABSLT TPS(%) 19.6
ENG SPEED(RPM) 0
BARO PRS("HG) 29.5
CALC LOAD(%) 0.0
MAF(LB/M) 0.20
COOLANT(°F) 201
IAT(°F) 169 this seems a little on the high side, but then again, a few things could affect that.
IGN ADV(°) 5.0
SECOND AIR N/A
ST FTRM1(%) 0.0
LT FTRM1(%) 7.0
ST FTRM2(%) 0.0
LT FTRM2(%) 10.9
Fuel trims look pretty good, Bank 2 LT is a little high, but not abnormal
VEH SPEED(MPH) 0
ABS LOAD(%) 0.0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
REL TPS(%) 0.4
THROT CMD(%) 16.5
ABS TPS B(%) 51.8
ACC POS D(%) 15.7
ACC POS E(%) 31.8
CAT TEMP11(°F) 996
CAT TEMP21(°F) 996
CAT TEMP12(°F) 746
CAT TEMP22(°F) 746
EVAP PURGE(%) 0.0
CMD EQ RAT 0.824
O2S12(V) 0.015
O2S22(V) 0.015
O2S11(V) 4.001
EQ RATIO11 1.000
EQ RATIO21 1.000
O2S21(V) 4.002
MIL TIME(h:m) 00:00
CLR DIST(mi) 26
CLR TIME(h:m) 05:32
CLR TRPS 3
MIL DIST(mi) 0
VPWR(V) 12.226
ENG RUN(m:s) 00:00
OBD2 STAT CA
O2 Monitor Tests
Diag Monitor Tests
O2 Sensor B1S1
Test $8E
MOD $00
MAX 0.000(V)
MEAS 0.000(V)
MIN 0.000(V)
STS OK
Test $91
MOD $00
MAX 0.000(mA)
MEAS 0.000(mA)
MIN 0.000(mA)
STS OK
[Not sure what the "normal" Toyota AFR (B1S1 & B2S1) Mode $06 Data is supposed to look like, but this seems wrong to me.]
O2 Sensor B1S2
Min V for Cycle
MOD $00
MAX 0.195(V)
MEAS 0.097(V)
MIN 0.000(V)
STS OK
Max V for Cycle
MOD $00
MAX 1.190(V)
MEAS 0.859(V)
MIN 0.605(V)
STS OK
Test $8F
MOD $00
MAX 2.998
MEAS 0.007
MIN 0.000
STS OK
O2 Sensor B2S1
Test $8E
MOD $00
MAX 0.000(V)
MEAS 0.000(V)
MIN 0.000(V)
STS OK
Test $91
MOD $00
MAX 0.000(mA)
MEAS 0.000(mA)
MIN 0.000(mA)
STS OK
O2 Sensor B2S2
Min V for Cycle
MOD $00
MAX 0.195(V)
MEAS 0.078(V)
MIN 0.000(V)
STS OK
Max V for Cycle
MOD $00
MAX 1.190(V)
MEAS 0.898(V)
MIN 0.605(V)
STS OK
Test $8F
MOD $00
MAX 2.998
MEAS 0.001
MIN 0.000
STS OK
Catalyst B1
Test $A9
MOD $00
MAX 9.994
MEAS 0.005
MIN 0.039
STS LOW
Catalyst B2
Test $A9
MOD $00
MAX 9.994
MEAS 0.005
MIN 0.039
STS LOW
[This seems to be the cause of the codes, but I couldn't tell you 100% if the cats are bad or not based on this.]
Ooh Mode $06 Data! You don't see too many people using that these days (hell, I don't play with Mode $06 very much myself, but I'll try and answer best I can.) Unfortunetly our factory TIS TechStream doesn't use Mode $06 (at least not that I found easily) so I'm not 100% sure how accurate the results are. But I highlighted the points I would look at.
There are 4 Catalytic converters on your vehicle, 2 are integrated into the exhaust manifolds.
If am to change anything, what do u suggest?
Fixed p0420 p0430
I had same problem. Here is what I did.
Replaced O2 sensors all 4 of them. Did not work. :(
spent $1600 replacing two cat converters. Worked.
My cat converters die at around 130,000 (check engine light popped). Cat held until around 180,000.
Cat converter lifespan is around 120,000 ~ 190,000 miles under normal maintenance. (change O2 sensors at 50,000 miles interval will prolong Cat converter lifespan)
My 04 4runner SR5 has 250,000 miles on its clock. No major problems except wear and tear parts replacement.
I wouldn't worry about the PO420 unless you have to pass emissions.
I've had PO420 for over a year now and the cause was cutting my back 2 cats out. The car runs fine and does not hinder performance at all.
But that's just me because my county does not have emissions testing and I just clear the code with my scan gauge whenever it pops up.
Cc
My p0420 and p0430 popped at 120k miles on the clock. I cleared the code and CC lasted until 180k
CC lifespan 100k ~ 170k (if you take care your car, CT would last longer but not forever)
Check your cat warranty first before you replace it.
if you're going to replace them, just replace the whole thing. (there are four sensors on the cat converters)
cost me around 2k
my 4R has 250k on the clock now. good ride. good ride.
OLD post but searched and this is the only thread with LT FTRM 2.
My ftrm 2 is 17.1%, which appears too high, any clue to what could be causing it, or what i cud do to resolve it?.
no CEL lights on dash
So Bank 2 LT FT is 17.1%? That is a bit high. I would guess you have possibly an exhaust leak or extra air getting into bank 2 side some how. 17.1% means it's adding 17.1% more fuel to the vehicle, which means it's seeing more oxygen somewhere. There's a number of things that could cause it, but if it's isolated to Bank 2 I'd guess something on the exhaust side of the spectrum.
Philthyphilthy
