P0500
ZionXIX
January 2018 update: SOLVED
I installed a used ABS ecu at the passenger kick panel and the P0500 cleared instantly and my odometer is now working.
If you have this OBD-II code, open up your ABS ecu and look for melted capacitors.
So the other day I started her up and the took off without a second thought and noticed that the speedometer was not working.
Pulled the OBDII codes and got "P0500" = Vehicle speed sensor malfunction.
I tried to do some research so as not to waste the forums time with lazy repeat posts.
In my defense i cannot access the following posts:
https://www.toyota-4runner.org/3rd-gen-t4rs/170398-abs-light.html
https://www.toyota-4runner.org/3rd-gen-t4rs/209449-abs-unique-problem.html
The connection times out so Im not sure what to do with those.
Google doesn't even give me the "cached" option for those pages.
I dont know if the 1996 2WD model gets speed information from the ABS sensors or a transmission speed sensor.
I saw lots of posts about a VSC problem in 01 02 models, but I dont think those apply to me.
First thing i did was check the ABS sensors. 3 of them are reading around 1750 ohms.
The last one was completely severed at the sensor location before I bought the truck and
I never had a problem with the speedometer until now.
Second test I did was jumping the "E1" and "Tc" pins on the engine bay diagnostic box.
When i did this before, I got the code for the right front ABS sensor (The broken one).
Now this new problem with the speedo has resulted in the ABS light not coming on at all during this test.
Instead the cruise control light starts blinking followed by the Airbag light a few seconds later. I'm stumped.
If there is a transmission speed sensor, I have been unable to find it so far.
Any insight would be greatly appreciated.
*If* you have ABS, your truck should use it for the speedo. Where was your truck originally delivered (US, or somewhere else)?
Does your speedometer still work?
The ABS system uses the wheel speed sensors, sends the signal to the gauge cluster, which then sends a modified version to the ECU.
-Charlie
This is a US truck with ABS on board. Speedometer is not working. All other instrument gauge are functioning normally. Are you saying there is no Vehicle Speed Sensor on the transmission? Also what is with the weird blinking of the cruise/airbag lights? If it were solely an ABS issue I would expect the (E1/Tc) jumper to direct me to an ABS problem.
ABS computer (on the pre-'01 trucks) doesn't communicate with the ECU, at least not for DTC's, I don't think.
No speedo = no signal to the ECU for vehicle speed. No speedo is caused by the ABS issue.
Solve the ABS issues and the ECU code will go away and your speedo will start working.
Now's about the time TheDurk should show up with info on how to debug the ABS and Airbag systems... :)
-Charlie
So I started investigating the Vehicle Speed Sensor. Its also know as the "No. 2 Vehicle Speed Sensor". It does exist! I found it attached to the transmission about 8 inches away from the drive shaft connection and right above some kind of bushings shock absorber thing for the transmission. It was caked in oil. I unplugged it and found oil inside the connector. Cleaned it thoroughly and tested the resistance at 660 ohms, well within normal range. Afterwards the CEL went away immediately but still no speedometer. Its really unusual because the Speedometer died at the same time as that CEL popping up. If the ECU is happy about the VSS, why isnt the speedo?
Jumped the ABS and still getting the blinking "Cruise" and "Airbag" lights instead of the ABS codes. I also cleaned two factory grounds on the driver side under the dashboard and 1 diy ground going to an aftermarket remote system I didnt know about. I would like to investigate the ABS system some more but Im not sure where to start.
That speed sensor is used ONLY by the shift logic to determine the output speed of the transmission. It does not drive the speedometer - the ABS system does.
If you had a non-ABS truck, then the VSS used for the speedo would be in place of the plug just behind the one in your picture.
-Charlie
-Charlie
You can understand my confusion, they occurred at exactly the same time. Do you know if the VSS is independent of the ABS? or does it tie into the ABS before making its way to the ECU. Because of the course the CEL popped up again today.
The ABS system is the "VSS" on ABS 4Runners.
So, ABS system gets the signal from all 4 wheels, processes that, sends the signal to the gauge cluster. The gauge cluster conditions that signal and sends that signal to the ECU. If the ABS system is not working, then there will be no speedometer either - and the ECU will throw codes for the VSS.
If you reset the ECU while messing with that sensor, it will take a while to throw the VSS code in the ECU. There is generally some multi-trip logic before that CEL code trips.
-Charlie
-Charlie
I actually never reset any of the codes. All I did was clean and test the VSS and the CEL went away immediately. So puzzling to me. Anyway I'm looking into the ABS now that I have the proper wiring diagrams.
Thanks to TheDurk for providing me with some year specific wiring diagrams. In regards to my wiring problem when jumping the "Tc + E1" on the Diagnostic port. I noticed in the manual it shows that the "Tc" pin is connected to the ABS ecu, Airbag sensor, and the Cruise control. Is it possible that this is my problem? Could there be a wire short to ground in the Tc circuit? I also noticed that the Diagnostic port (aka Data Link 1) has a pin labeled "Ts" specifically for the ABS ecu and a pin labeled "TE1". Can these other pins be jumped to read DTC codes?
Im trying to track down the three components connected to the "Tc" pin on the diagnostic port. According the FSM those three components are the ABS ecu, Cruise control ecu, and the Airbag Sensor Assembly. I found the ABS ecu in the passenger kick panel. The cruise control ecu I found behind the ashtray underneath the radio. The FSM says the airbag sensor assembly should be in the same area as the cruise control ecu. I dont see anything in there labeled for the SRS system. Strangely enough there is also a box labeled ">ABS< Antenna Relay". Never heard of that one. So has anyone actually laid eyes on the airbag sensor assembly?
I think I have found my problem. On a hunch I opened up the ABS ecu to examine the PCB board for damage. Im getting deja vu from my ECU problem last year.
sounds like you got a critter problem...
I cleaned it up a bit last night as part of the post mortem. Its definitely a blown capacitor that proceeded to melt the neighboring resistor. The same exact thing that happened to my ecu. I have read about problems with the capacitors from this era where some of the suppliers may not have kept as stringent quality control of their products resulting in some of the capacitors being bad. Otherwise I just blame the island for most of my problems, helps me sleep at night.
Thanks for the link, I just added it to my watch list. I tried to examine as much of the harness as possible but its not easy. A colony of ants did take up residence next to the ABS ecu during the last round of hurricanes. I promptly evicted them.
Thread Update:
I installed the used ABS ecu and the P0500 went away immediately. The speedometer is now working.
Hi, I cannot speak to the 96-00 models because the 01-02 3rd gens have vsc. I have an 02 Limited which is different than the SR5 in terms of specific part numbers for this issue. Sounds pedantic but it matters.
But I replaced the transmission sensor and still had no Speedo and same p0500. Then as some threads have suggested, I replaced the printed circuit that goes on the backside of the cluster (Toyota has discontinued it and it does not exist at any dealer in the world so you have to go junkyard and be careful to make sure it is exact match). After the printable circuit was replaced the code still persisted with all vsc abs and brake lights illuminated with still no speedo. I took apart my abs ecu and everything looked perfect inside so I thought I was just stuck with this problem for life. Thought I would try a junkyard abs ecu on a whim and got cheapest one on eBay that looked rough on the outside casing for the unit. Oh ya, also drove cross country with no Speedo and had fully resigned me myself to this life sentence of permanent lights and no Speedo - however...I put in the rusty eBay abs ecu and all lights are GONE and Speedo is back working!!!
Seriously thank you to this community.
First time ever posting on any forum like this btw. I owe many of you as I have nearly replaced every single part (denso only) on my 4Runner and encountered every single one of the common known issues.
ABS light
ABS Unique Problem
DJNutshell
