P1300, p0303
kolelt
Today, driving my truck threw check engine light. First one and only one was p0303. Cylinder 3 misfire. Pastside coil. I swapped that coil with cylinder 1 coil. Started it up, seemed to run like shit still. Cleared the code shut the engine and started driving. Then all of sudden it seemed fine again. Drove home about 10 miles or so. Idling in the driveway. It threw 2 codes. One was p1300 and the other was p0303.
https://www.engine-codes.com/p1300_toyota.html
I had extra coil packs laying around. Swapped it around it. Nothing changed. Then after clearing the code it seemed fine but still at idle it seemed little rough although no CEL code. Went to aurozone and got new spark plug wire set. Go to change them I checked all spark plugs. They were bone dry. However cylinder 4# he spark plug boot had little bit of oil on it. Maybe my valve cover seal is going to shit. Anyways, replaced all the wires. Let it idle for 30 mins. Seems a lot smoother and better then before.
The old spark plug wires were NGK blue ones. Not 100% sure but about 2-3 years old. Seems to soon for it to give me issues if that's the actual issue.
Spark plugs are OEM Denso dual ground. Probably 10-15k on them.
Checked oil dip stick. It was clean, checked radiator. It was topped of. No coolant was coming out of the exhaust either.
So my question/ concern is... is it possible for spark plug wires to cause this ? Because I'm little skeptical that the NGK wires would go to shit so fast. Or maybe it's something else. But changing the coil pack would have caused the other cylinder to misfire if it indeed is the coil.
I blew a hole in a Denso spark plug boot early last year in cylinder #4. Ran like crap, threw the PO304. Replaced the wires with Sumitomos, all new Denso coils, both from Amazon, and been good to go since.
How did the spark plug from cylinder#4 look?
If an injector is failing it can go in and out. I just got the misfire code for cylinder 1 and found it to be the injector going in and out.
But yes I have seen wires go bad within 30k miles. But this was usually on a 400+whp turbo 4 banger that would eat plugs and wires for breakfast.
Plugs looked dry and clean.
My friend suggested ditching the dual ground spark plugs. Because no one even sells them besides toyota. And just get iridium spark plugs. Good ones though.
I'm in traffic now. In neutral rolling... scan gauge is reading 10-12 mpg while just rolling in neutral ???
I have 95K on my blue NGKs and still going strong. I do put dielectric grease on both ends whenever I disconnect them which I'm sure extends life.
Could anyone shed some knowledge on the p1300 code.
And so, if my wires were bad. That would explain why swapping the coil pack didn't change the misfire in different cylinder ?
I did a compression test on passenger side. And they were all the same.
johnnya
