P2238
chrisonfiya
2004 T4R V6 SR5 250k+ mileage
showing 1 error code P2238. had previous codes so what I've done so far was
-replaced both upstream o2 sensors and the passenger side downstream sensor along with a new catalytic converter (passenger side).
-put in a new MAF sensor.
-new EFI Relay fuse [R16 - EFI]
-new Power Relay fuse [R17 - A/F Heater]
what else can I do since I can't pass inspection. Also I've cleared the codes many times after doing something to the vehicle.
Factory Service Manual has these under P2238 code:
open or short in A/F sensor (bank 1 or 2)
air fuel ration sensor (bank 1 and 2)
A/F relay
A/F sensor heater and relay circuits
I am reading the V8 manual FWIW.
A/F = air fuel
After reading your post of what you have done you may have some wiring issues. A pulled 02 connector would cause a problem. How good are you with a multimeter? And do you have the wiring manual for your engine / model year?
A/F relay
A/F = air fuel
no never used a multimeter and i don't have the wiring manual. i will ask a shop friend about a pulled o2 connector though. maybe i can get some clarity of that.
There are many places the wiring could be bad. A wiring schematic and some time may point to your issue. Wiring issues are always challenging and tedious.
