Pads and rotor suggestions?
getsomeVA
hey all, looking for a good aftermarket suggestion for pads and rotors for an 08 V6. Original OEM brakes on it now with 47K on them. Hate to replace em already, but rotors are warped from highway driving.
You'll find a wide range of suggestions for pads.
Hawk pads are excellent...Bremo too. I've been using Wagner for the past 30 years.
Highway driving has NOTHING to do with warped rotors. What causes warped rotors is when the rotor gets HOT (usually from stop and go driving) and then a sudden cool down (driving through a puddle). In fact driving on a highway will help prevent warped rotors because you're not doing a lot of braking and the air flow keeps the rotors cool.
Also the 4runner has a different setup then most other cars. Their calipers have 4 pistons. A known problem with this vehicle is one or more of the pistons stick prematurely......this will cause the same symptom of a warped rotor (pulsating brake pedal). I'm guessing that one or more of your calipers is bad and that your rotors are fine.
I've been using Wagner ThermoQuiet's and have been happy with the performance and low dust on rims. Got a killer deal on Amazon for $29. I had to replace my rotors too due to being warped, I forget what brand though but they have held up great. I did have the seized piston in my caliper though long after the new rotors and pulsating went away.
I have had very good experience with Akebono pads on both my cars. Dust free and very good brake feel.
As for rotors, I was in a rush to get the job done, so picked up some NAPA brand rotors for $125 and they are working fine (too early to tell about longevity).
Stick with dealer pads. Anything else the best you can hope for is that they perform as good as them. You are not going to have to worry about dust or squeal with them.
OEM pads are very good pads. The only thing you have to worry about them is their highly inflated price. Wagner is one of the OEM brake part manufacturers for many auto manufacturers.
Now here's a twist...Many vehicles made in Asia use Akebono brake pads. But when the dealer here in the US get's their OEM parts from companies like Wagner.
I too have an 08 V6. I bought this kit for $200 with free shipping. Both on simple in about an hour altogether. Look great.
Bob
That is very true. I remember getting my last pads and got a set that included the shims. I wasn't expecting to see 'made in USA' on them.
I use wagner pads and rotors I got them at Advanced because they came with a lifetime replacement warranty. I used to have EBC dimpled and slotted rotors with EBC green stuff pads they were warped within a year.
Centric premium blank rotors. There is no need to waste money with drilled or slotted rotors. Money is better spent on a quality alloy rotor. Centric premiums are also coated black on the hats and vanes so they don't rust.
I run EBC green SUV 6000 pads. Great street and mild performance/towing pad. More agressive bite than stock and better feel and response.
If you want a very agressive pad, get the EBC yellow SUV 7000 pads. They are a bit cold blooded and take a stop or two to get up to temp in the morning. They have a very agressive initial bite and a very positive feel like a performace car.
Also, flush your brake fluid out with fresh fluid.
I use ebc green stuff pads 6000 series and ebay brakemotive drilled and slotted rotors, rotor can be had for around 150-175, pad are around 130 out the door i think. My next upgrade, i will try the ebc yellow pads.
When I changed them I ran w/ EBC green and Brembo rotors. Got a great deal from autopartswarehouse.com
Good luck
I just ordered EBC rotors and Greenstuff pads. Will report back when I get them installed. These are for the bigger 13.3" rotors that the sport/limited have.
EBC-DP6993 6000 SERIES PAD SET Shipping From Manufacturer $65.16 1 $65.16
EBC-DP71657 7000 SERIES PAD SET Shipping From Manufacturer $109.34 1 $109.34
EBC-USR7161 DISC BRAKE ROTOR Shipping From Manufacturer $180.34 1 $180.34
EBC-USR7238 ROTOR KIT LEXUS/TOYATA Shipping From Manufacturer $226.41
I bought Centric premium rotors and Hawke LTS pads. Hope to have them installed tomorrow, so more feedback to come.
Who the heck cares about lifetime warranty on a wear item such as brakes? First off that means they care about lasting forever vs stopping. Second, you'll just get a prorated refund on the brakes which will be near nothing. I'd rather change brakes often and have PERFORMANCE.
I just got Centric Premium rotors and Akebono Pro-ACT pads... I've been extremely pleased with Akebono pads in the past. Check out Rockauto-dot-com.
Jhunt
