paint discoloration from cleaner question opps or can be saved???
4for4runner
i was cleaning the 4runner and used the oil eater product. they say if you let dry on aluminum or painted surfaces it may caused paint discoloration. I might have let it dry to long before i got to it and have drippy streak marks running down the areas i used. is this permanent or can it be buffed out ????
am i screwed :ybrick:
gov you the man. thanks so much. i hope so............. when its wet they disappear so im thinking i had a good chance. give you an update later. :)
Make sure you use a finishing buffing compound. If your buffing compound is too course you'll have a whole bunch of ugly swirls in your clear coat. I know from experience... it's FUGLY in the sunlight when you get those swirls :)
Good luck!
enunciatechive
