Painted my OEM 98 4runner rims...debating if I should clear coat after painting
flappn
So my 98 4runner rims where looking very very bad...so I took the time to prep them for paint (2 hours a rim). So I primed with etching primer then filler primer and then painted and they turned out great. However I'm reluctant to clear coat them as I don't want them to be overly shinny. What do you folks think? And if you did clear coat which of the Duplicolor clear coat products would you use?
Thank you
I would definitely clearcoat. It will add a lot of additional toughness against chips. If you don't want a shinny finish go with a matte or semi-gloss. My only recommendation is to use the same brand clear as you did basecoat to ensure proper bonding.
Just my $0.02
Definitely clear them.... do the first few coats nice and shiny.... then on the last couple of coats.... mist the clear on them... makes it look semi-gloss... and kinda textures the finish. I've done that with a few projects....
