Paracord Grab Handles - Ohio
How are these being mounted? is there some piece of metal or is it just hooked up? Sorry from the pics already here I can't tell.
There is two loops on each side of the handle to put the factory screw through!
Have any 5th gen owners attached a paracord handle as a "loop" on the ds a pillar, using the bolt under the airbag bolt cover to attach both ends of the paracord handle? It has been discussed on the 5th gen forum ad infinitum that the 5th gens no longer have the molded grab handle on the a pillar. I'm wondering whether the dangle of the handle, configuring the paracord handle as I've described, would interfere with sight lines or have some other negative effect.
2016 sr5p super white 4wd
I shipped some handles out to asakite and his runner is a 5th gen! Maybe he can give some input
So for any 5th Gen owners wondering if this will work, I gave the suggestion by Toy2G a try and I think after adding a "yet to be figured out" piece of cosmetic trim, it will work nicely. as far as strength of the anchors, I did give it a good tug but didn't hang off it or anything. I am going to wait to do the other 3 after I figure out what I am going to do about the cosmetic pieces I will need to cover the exposed parts. Also probably get smaller washers as you really wont need much, the hoops on the handles are just big enough to slide the screw through.
20160503_114655_resized.jpg~original
20160503_115341_resized.jpg~original
20160503_120258_resized.jpg~original
As far as adding one to the pillar where Toyota so rudely stopped including one, I can't help as I am only adding these to the over heads.
Sorry.
-S
They look good installed!
So finding a thin square washer large enough to cover the exposed area, but has an internal diameter that isn't too big is harder than I thought it would be. I got this one thats thicker on one side as a temp solution until I can figure out something better. Not sure I trust the strength of the handle since the screw doesn't go as far into the anchor, but It will work cosmetically until I change it.
20160504_200010_resized.jpg~original
20160504_200057_resized.jpg~original
Here is the pic. I was trying to pm you, I will not be using the plastic piece, so it is going from the screw up between the seat bottom. If that makes any sense at all.
Hey 08yoter, the pull handles for my rear seats got here last week. Finally got them put in with just a couple glitches, no big deal really. Had to drill the bracket hole out to 1/4" for the mounting screw, and the pulls ended up being almost 12" long with the bracket, I was looking for 9" over all, but I can live with it just fine. Here are a couple of pics.
I can make you anothe set at 9inch including the bracket without a problem and get them shipped out. That never even crossed my mind man!
I ordered a pair of the headrest handles from 08yoter and received them in the mail two days later. Great quality and they really help my daughter get in and out of her carseat. :thumb3:
