Part number needed: valve cover bolts and oil cap O ring
Could not find it there either. I was able to find part numbers for "standard parts" at the bottom of the page I was looking at. One of these is probably the part I need, but it is difficult to verify.
90109-06275 is the bolt and seal assembly
90105-06127 is just the bolt (90210-05007 is the seal)
90430-37140 is the oil cap o-ring (gasket)
Ok, you guys are the the best. This place rocks!
For those interested, it is cheaper to buy the bolt and seal as a set. Even if you weren't planning on replacing the bolts, it is worth doing at the combo price. You never know if you might find a broken or damaged bolt when doing valve cover gaskets.
Per Camelback:
The bolt alone is $.76 ea
The seal alone is $.95 ea
The bolt and seal combo (thanks 4Runner4Leon) is $1.01 ea
for future reference, call your local dealer. when i was looking for the studs for the upper water neck i couldn't find them anywhere. called dealer, took him all of 30 seconds to pull up the diagram and give me the number.
