Part or Fix Her?
Ok all here is what all will be done to the used engine:
Valve cover gaskets with spark plug tubes
Manifold gasket-intake and plenum
Manifold gasket-exhaust
Lower end gaskets-oil pan, crankshaft, timing, etc. (Should this include a head gasket?)
Rear main seal
Timing belt, water pump, tstat, idler, etc.
Oil and filter change (will upgrade to synthetic)
Coolant change
Gaskets are FEL-PRO. TB, water pump etc. is the EBay kit everyone uses.
Additional items I will have done:
Spark plugs and wires
Fuel filter
Transmission fluid and filter change - I will do
Differential and tcase fluid change to synthetic - I will do
New O2 sensor - only because I have a new one that was never installed
Anything missing? Thanks!
patnewton
