Parting 2000 4Runner Limited 4WD Marysville, WA
Would by any chance still have the rear hatch/tail gate trim piece? If so how much shipped to 50138? Attached is a pic of what I'm looking for, Thanks
[MENTION=81818]Illicitdream[/MENTION] I will PM you
I need a wiring harness that goes from the Master Brake Cylinder to the ABS unit.....my dad drilled through mine and now my brakes dont work. What would the price be to ship to 29681
[MENTION=115455]JeepKiller[/MENTION] What you need is from 2001-2002, the 96-00 Is vacuum brakes, not electronic like you have.
How much for shipping for the flare?
[MENTION=122575]98run00taco[/MENTION] $25 ship
Do you have the DS Inner Fender Lining available?
[MENTION=91425]LOSTR4[/MENTION] Sorry, no
Crap I thought the 00 would work
Sorry :/ [MENTION=85046]nissanh[/MENTION] Has a 2002 I believe....PM him, he would be your best bet. Just make SURE you compare harness part numbers, and keep in mind you have to tear your entire dash out and more to replace harnesses.
Do you have any of these available?
-Steering wheel (what condition is it?)
-Center storage console - is this one piece that goes all the way to the automatic/4wd part?
-Speedometer/tachometer with cables?
-rear plastic cover for the side trunk storage box
[MENTION=130034]Wakko[/MENTION]
-Steering wheel torn up like they always are
-Center console complete with E-brake handle, and mount bracket $100+ship
-Speedo $75+ship has 19x,xxx miles on it. These are electronic, no cables.....
-Rear storage panel cover $25+ship
I'm just looking for the one that goes from the master cylinder to the abs box in the engine compartment thanks!
Gotcha! Nissanh should still have you covered
Hi. I need the 5-way junction box for towing. The box I'm referring to is located in front of the driver's side tail light behind the interior trunk panel. It connects to the body via a ground wire that's held on by a 10mm bolt and has two harnesses that connect to it. I need the box and the trailer harness that's attached to the hitch. I don't need the main harness that goes into the body. Hope you can help me. Thanks!
