Parting 2000 SR5 4Runner 74k Marysville, WA
I found them. Yeah, the box was in the recycle bin - trash day tomorrow.
Do I need to wire wheel the rust off and paint? A lot of paint is falling off due to rust under it. I'm not sure how a tow hitch is treated.
I assume lock-tight for the bolts?
[MENTION=107625]toyorgy[/MENTION] Depends on how picky you are for the rust. A little rust is complely normal for a vehicle this many years old. If you want it to be super nice, you can do that. However the hitch seems to get blasted with all manner of salt, rocks, sand, and anything else your tires can kick up so spraypaint may just chip off and worsen the issue. No need to loc-tite the bolts, just make sure they are torqued properly. The FSM should tell you proper torque.
[MENTION=107222]HiLife[/MENTION]
I have the upper and lower control arms, normally sell $50/ea ($200 total), but you have bought a lot from me, so I will sell for $150+shipping ($37.50/ea!). Might be cheaper to ship in two boxes, but I will know more once I get them boxed up. Just bear in mind suspension is heavy, but I will try and save you as much money as possible!
Im going to wait until later when I can tear into my interior to see what I actually need.
at this point I may need the rear passenger side seat belt and trim in gray/silver. like I said I have to look into it to make sure the belt isn't just caught on something from getting it fixed after my accident. but if you have those parts I could be needing them at some point!
[MENTION=60096]sportrunner2001[/MENTION] No worries, just let me know if/when you are ready to buy
I need a drivers side headlight assembly....99+ version...
Let me know if you have one
[MENTION=51127]Dous[/MENTION] Only one I have has a small rock hole in it :(
Hmm, that could work, my glass is actually OK, just the plastic housing broke
Final week! This truck has had a great response, but sadly it's time to let her go.
Let me know what you need and I will save it from this one!
thanks
Hey DC, thanks for the parts last month. Those rear carpet pieces cleaned up real nice. I have an odd request here. I need the cross member piece circled in the pic with the hardware too if possible. Thanks again!
[MENTION=107674]JRZEE2000TR4LTD[/MENTION] Glad to hear it worked out! be sure to leave me feedback in the Buyer/Seller feedback setion :)
As for the crossmember, this is the transmission crossmember, correct? The one that the actual Transmission mount bolts to? Not the one BEHIND that which is just a crossmember. I want to be 100% sure I send you the right part.
Yep, that's the one. Yours has to look better than mine (rust has all but disintegrated the passenger side where the 2 bolts go through) :wtf:
Just make sure it's coming from a vehicle with a VZN185 or RZN185 Model code. It shows 2 different part #'s depending on the model code.
Oh , while I'm thinking about it, (and I'm sure you don't have one) a brown steering wheel.
I'll be sure to leave some positive feedback. I didn't know it was there.:doh:
The other model codes are 2WD's, so you must need one from a 4WD. I have it no problem, $35+shipping. I have the bolts that go with it, and no rust!
Looking for the spare tire hangar assembly. Need to get mine off the rack. Would also be interested in the airbox & tubes to the throttle body if you still have them.
allcarhistory
