Party Mode Button relocation?
nglayton
Senior Member
So I'd like to move the Party mode button to a different spot. Plenty of blank spaces on the other side of the wheel. The factory harness is just a short little tail that just reaches the current location by your right knee. I'd rather not cut the factory harness and splice a hack into the wires.
Has anyone else done this? Does anyone make a pigtail, that I can use to move this switch about 18-24" to the other side?
Even part numbers of the male/female connectors would be great and I will make my own...
It wasn't very fun :-O
This Party Mode button was present on earlier Gen5 4Runners, and was located on the knee-panel to the right of the steering column. My 2021 had a blank installed - by 2021 the Party Mode button was no longer present. I used this blank instead for my Redarc Brake Controller knob.
The Party Mode switch was intended to boost rear-hatch audio, when you were parked and had the rear hatch open. It did this by diverting rear-door audio to the rear speakers instead.
Where is this party mode to begin with? No idea what you are referring to, but sounds like fun.
Here you go, I want to move this to the left side of the wheel.
