Passenger seat heater….
Snackie
Member
Quick question….my passenger seat heater switch light stopped working. I don’t think the seat is getting hot with. Is this most likely the switch? I believe they share a fuse and drivers side works fine. Just wondering if this is a known problem or if I’m going to have to do some troubleshooting?
I don't think this is a common problem on 5th gens. Any chance something was spilled on the switch?
Since your driver seat heater works, and the switch isn't illuminating, I would definitely suspect the switch is the issue.
Looking at the wiring diagram, it appears both go to the same fuse (S/HTF FR) in the driver side junction block.
Probably a long shot, but check the connection on the switch isn't loose. Beyond that, I'd say it's probably the switch itself.
2001ATL
