2016 Trail Premium Window Switch Inoperable
Brad88
Wife's 2016 4Runner 140K miles front passenger window switch from the driver side does not work. Passenger front side does. I believe 2 months ago we had some issues with several windows from the driver side but then started working after a few seconds and didn't think much of it.
Since I have never had a single issue with this since we have owned it, I have not had to get familiar with any issues. Does this seem like the switches in the driver side door are bad?
No recent disconnect of the battery or any electrical issues. The reset function does not do anything on the driver side as well. If likely the switch, is there some place other than the dealer to go for OEM or better toyota parts? I typically don't go to part stores or Amazon for car parts unless it's an emergency.
I’d start by pulling the driver-door window switches and spraying down all the connections with DeOxit. Stuff is pretty amazing at what it does, if that’s what’s needed
https://www.amazon.com/gp/aw/d/B00006LVEU
Otherwise as far as I know Toyotapartsdeal.com will usually have the best prices if you need to actually replace the switches
