Passenger side floor wet
phishtaco
I've searched some threads but I'm still having some water leak onto the passenger side floor board. Things that I have done. Does anyone else have any thoughts? I'm leaning toward windshield seals.
Cleaned and poured water down the sunroof drains. They drain out.
I don't think it is the ac drain because it only happens when it rains.
The bottom trim along the windshield was slid over towards the drivers side about an 1" or so and popped up in a spot. I adjust it over and tucked it back into the groove.
We had some rain yesterday and I felt some dampness on the floor below the computer on the A pillar.
The windshield has been replaced at least twice and does have a small spider near the rear view mirror. So I should be getting another from the insurance company as a replacement, but I'm not sure if they will replace it or try to repair it.
I do have a tiny 1/4" hole that the xm antenna is poked through near the cabin filter.
I think I have seen a water drip onto the outside of the passenger kick plate panel.
Sorry for the long post.
Check out this thread: wet floor
I, along with several others, had similar issues after windshield replacements. I'd wager it's the windshield trim and exposed holes in the A pillar. Pull up the weatherstripping or pull the interior A pillar trim and run a hose down the windshield sides. Takes about 5 mins to test. If it's the A pillar holes you'll know right away so don't go drowning them haha.
Good luck!
Jhunt
