PIAA 17202 LED Bulbs
I haven't noticed any so far. I've used the Satellite radio, and Bluetooth streaming and sounds the same as before.
The lighting is a DRASTIC upgrade. I can't wait to do the rest.
Are you using them as fogs or low beams? If you using them as low beams, how did you fit them in the projector housing? I bought the pair, but with the "driver" box so big, I just do not know how to install them. Thinking of using them as fogs.
Any advice will be appreciated...
you mentioned "2010 Trail"...now I am thinking... No projectors, right?
That is correct. No projectors. I have them installed as low beams just to test them, but think I'm going to move them to fogs instead. I just realized that they are more than likely not DOT approved.
Sent from my SM-N910P using Tapatalk
I was going to buy them as well for my 2015 4Runner but the projector housing looks like its size would make the PIAA Fan on the back of the LED Bulb hit the projector housing or come so close that the PIAA fan would get blocked and be very restrictive by the projector housing cap.
Old thread, but I installed the PIAA H11 LED bulbs for low beam headlights in my 17 Runner recently and I'm really happy with it. I wasn't expecting the intensity of HIDs, but I was surprised, it's actually really close. The PIAA H11 LED kit is fully adjustable to get the best results in reflector type housings, but is already preadjusted for projector type like in newer Gen5 Runners.
The bulb with fan fits easily behind the dust cover, but the problem is that the controller doesn't fit in the headlight housing, so some modification will have to be done to bring the cables out while keeping things sealed. Currently I drilled a small hole in the dust cover, put a rubber grommet, and ran the bulb wire and car side harness out. Then I sealed around and inside the rubber grommet with silicone.
So far so good, I haven't had any problems with condensation getting in the housing, but I'm planning on redoing this installation. I have an extra set of dust covers on the side that I'll be replacing the ones I drilled through, and I plan to back out the car side harness through the factory hole at the bottom of the headlight housing, then plug it with a new flush mount rubber push plug and have the bulb wire come out through that and seal it with silicone for a cleaner install
Cpn2mss
