Pics of my 2012 4Runner Limited
rpuranik
Enjoy !!
Mods : Replaced LB, HB and Fog Lamps with PIAA Extreme White Plus bulbs, Black Rhino Sabi 20x9 Wheels, Michelin LTS M/S2 275/55/R20 tires, Stubby Antenna, All state window tint.
Very nice..
1. You have no full view side picture, I think that will be a good point of view.
2. Is it 4WD?
In the picture of the rear shot, does your left side sit slightly lower? I have noticed that mine does and it is a bit more noticeable after I had lifted it. Maybe yours doesn't and it is just the angle of the photo.
Driver side lean is normal due to the positioning of the gas tank. It will be more level on an empty tank. I believe some people with aftermarket suspension have been able to reduce the lean a bit, but it's always a trade-off between full tank lean versus empty tank lift.
Okki
Okki
Thanks Okki
Lightbulb type
Just a quick question, which PIAA Bulbs did you use? Was browsing around and notice they made an H1 all the way up to H13 Xtreme White Plus, wasn't sure which one actually fits. Def seems the way to go till I save the money for an HID retrofit :D. Thanks in advance.
The High Beam is PIAA Extreme White Plus 9005, the Low Beam and fog/driving lights are PIAA Extreme White Plus H11 bulbs. See tirerack for bulbs and pricing.
Can you post pictures of the headlamps with the lights on at night? Just want to see the color and the brightness. Thanks.
I have been thinking about doing this switch myself. I researched some awhile back but couldn't come to any conclusion...
Is the light quality and output noticeably better? It's a worthy upgrade? Thx.
Rialm
