Pics of stage 1 4runner transformation
jdub24
Pics of jdub24's 4runner
I've been working the past couple weekends putting this stuff on, and here's what I've got on so far:
3" Revtek Lift
16" American Racing Mojave Wheels (with Teflon coating)
Nitto 285 All Terrain Tires
PIAA 525 Hi-beam/Low-beam/Blue Halo Driving Lights
Westin Safari Bar
JAOS Skid Plate
Borla dual exhaust
K&N FIPK Intake
I've still got a couple more things in my garage to put on, but I couldn't wait to post these pics....
I didn't install the lift kit or the tires/wheels, but everything else was straightforward and simple to install. Just hand tools, patience, and common sense.
3" Revtek lift - I'm very happy with this lift. At first, I was worried that 3" wouldn't be that noticeable. However, when I went to pick it up, I was pleasantly surprised. You can definitely tell this 4runner has been lifted. It's not obnoxious at all, and you don't have to jump or climb in the truck to get in either. Overall handling and street manners are pretty close to stock. Sometimes, at high speeds, it feels slightly "looser", but that's to be expected any time you raise a vehicle's center of gravity. The only thing I don't like about this lift kit are: gas mileage went from 18.6mpg to 13.5 mpg.....(I knew that would happen though....)
American Racing Mojave wheels and Nitto 285s - I love these wheels. They're coated with Teflon, and I swear they're the easiest wheels to clean that I've ever seen. Stuff slides right off. The tires are fairly quiet until about 85+, then they get a little noisy...I'm very happy overall with this combo.
JAOS Skid plate, Westin Safari Bar and PIAA 525 driving lights - I chose the JAOS skid plate for it's looks and simplicity of installation. I think it gives the truck a little bit "meaner" of a look. I like front bars clean and simple looking, that's why I chose this bar, combined with the PIAA 525s, and I think it looks pretty sweet. I love the PIAA lights. They have a lo/hi beam switch and when the main bulb is off, there's a little blue bulb that stays on and gives the light a "blue halo" look to it. I haven't measured anything, but these things really increase visibility at night a LONG ways.
Borla dual exhaust and K&N FIPK Intake - This combo really woke up the engine. I haven't had my truck dyno'd, but the ol' butt-dyno swears there's a little bit better takeoff, and a little bit better passing gear now. Both products included dyno sheets showing 9 & 10 hp increases. As for sound, the 4runner sounds like a truck now! I love it. It's nowhere near obnoxious levels, it's a nice mellow grumble at idle and cruising speeds. It really sounds angry when I mash the peddle though. I have the V6, so I would imagine the V8 4runners would sound even better!
Overall, I'm pleased with my changes so far. It's nothing major yet, I'm still searching for some reliable source of forced induction....I'll keep you guys posted with other mods I do....
I like the wheels/tires combo. I was actually on the American Racing website last night thinking that the teflon coated Mohave wheels would look good on a truck.
Thanks for the kind words.
Yesterday, I installed a vented OEM Toyota hood, a la Sport Edition 4runner and some blacked out headlights. Took about 3 hours total. They both look pretty good. I'll post pics of those later along with some stereo stuff I've done also....
New pics
There are a couple more pics of how I've mounted my iPod in my car. It was very simple with the spare accessory outlet and little ash tray slot there next to the shifter to get the iPod bracket and iPod charger mounted.
All I did was wire the input wire to the auxillary input on the back of my radio, plug in the iPod charger in the outlet, and buy an iPod cup holder mount. I cut off the bottom of the mount that would've went inside the cup holder, wrapped some thick rubber around the bottom where I cut it, and stuffed it into that little rectangular slot with the spare outlet. I put a little more rubber inside the slot to keep things tight and snug, and voila! The iPod sits nice and solid in the bracket, it's directly connected to the radio, so there's no FM modulated garbage anymore, and by using rubber, I didn't have to drill anything to get the thing to stay put. You can't see the rubber from anywhere in the truck either....
I've done some more stereo stuff, but I'm not gonna take pictures of speakers/amps/radios/etc....
I'll post the pics of the new hood w/scoop, and new blacked out headlights later.
You've got a great looking truck! I really like what you've done to it. Now take it off road so you can earn 4ROTM!
gas mileage
I just noticed your build...very nice! I am looking to install the the OME lift kit from www.sleeoffroad.com for my 4 Runner.
About your gas mileage: I don't think it is as bad as you think. I am guessing that you didn't compensate for the new tire size so in reality you are covering more distance per revolution than with the 265 stock.
To get the real gas mileage you'll have to factor in the larger tire diameter.
Thanks for the compliments.
As for off-roading, I'll have to take it on a road trip for that. There's nothing really to drive through around here. All we get are mud-holes here in SW FL. They're some deep and nasty mudholes, so I'll probably be playing in that muck sometime soon. However, there's really nowhere around here to flex the suspension....
Hey jdub24
I am installing a Westin Safari light bar this weekend. I am also looking that PIAA 525 driving lights like you have. Could you explain to me how they are wired? Not in major detail I am sure those will come with the lights, I am just curious how the Hi/Low combo works. Do you tap into the power of the Low beams and the power of the high beams? I have read the instructions for wiring up Hella 500 lights, and of course they are only supposed to work with High Beams so you wire into them. I am just trying to figure out how you would wire the PIAA's up so it knows which beam to turn on.
Thanks!
