Pictures of Wheel Spacers
Clemsonfan15
I'm considering getting some wheel spacers, but would like to see what they look like before I buy them. I don't want the tires to stick out too far.
How much does a shop charge to install them?
Thanks.
a good pair of spidertrax will run about 200 i think. but IMHO your runer is perfect and youre going to make it look cheap, like a jeep.
JA seems to be the answer to so many questions! This is about a 4th gen but the part/procedure is the same and there's pics of the spacers...
http://www.top4runners.com/ja/2007/wheelspacers.html
:cheers:
Yeah, I've seen that page before. I wish he had before and afters of his 3rd Gen and that it had the limited flairs. I even searched on here, but just can't find any pictures.
Yeah,2000runr, Spidertrax are $200 a set. I'm not talking about sticking out even a quarter of a tire.
Basically I'm just trying to find something to spend some money on and this came across my mind. :p
are you lifted? if not, the spacers will make you rub in the front. I had 1.25" spacers with 265/75/16 tires before i put i lift on and rubbed like no other. i couldn't even take easy turns with out the dreaded sound of my tires tearing apart the plastic.
why don't you just hang a string from the flares and measure how far out you want to push the wheels, and then order a spacer of that width?
Oops, forgot you had sequioa wheels. With the offset of those wheels and the spacers rubbing should be a little less. I was running spacers on mine with the stock rims/offset.
If you are looking to spend $200 dollars then my suggestion would be sliders or a lift. But that is my opinion and I will always choose function over form!
4xInovations.com comes to mind, and he has sliders for your price range :-)
Yeah, I hear ya. Lift is definitely out, just got new tires and it's not practical for me.
Those sliders look pretty nice and aren't too expensive. Do they come painted?
So with those Tacoma rims do the tires sit flush with the fender? It was hard for me to tell from those pictures.
It is now flush with the limited flares, which is what I was after with the spacers. As usual though, I'm thinking about changing it out to different rims again. Don't tell my wife though...shhh....
Spacers
I have the All Pro 1.5 Wheel Spacers, they are Hubcentric to work with your factory hub and your factory wheels.
If you look closely at this pic, you'll see that my wheels flare out a lot more.
http://www.allprooffroad.com/tech-info-mainmenu-63/spacers/toyspacers
