GottaBeTRD
EF!!! guys i cant get the glass seperated from the housing. its leaving small chips what should i do?
everytrhing is still reall dry i cant even break the surface im doinf 300 for 7 min
i cant really mount my LEDs where i want them unless i drill a hole. would these be a bad thing?? say if i seal the hole up when im done running wires through it?
As long as you seal the hole properly you're good.
BTW, the 1st retro you ever do is a true learning experience. They get easier though the more you do them.
I know it's late in the game, but for grins, here's my retro I did a few years ago. Still working great to this day: Another HID Bi-xenon Retrofit Install *PICS* - YotaTech Forums
Looking good so far! It's true, the first one is definitely harder than the rest!!
Did you figure out how to get the shroud on the projector properly? Looks like it... I usually use the centering rings from TRS. Makes it simple and sturdy.
Man, I can't wait to get my retro started for my new Runner.
Don't sweat it man. Took me a week to do mines cause I took my time and had a whole bunch of other **** going on.
Make sure you measure and test fit on truck. That's where I messed up. One side is a little off center but I kind of grew onto it because of how wide of a spread of light output I get haha.
But yea the housing has just minor tuning of tilt so don't rely on it.
Also I didn't realize after wverythig. Looked good and jb welded, after putting the bulb in that hit my coolant. I never checked because without the bulb in it fit. Things like that make it difficult, I was lucky enough I could just relocate the reservoir else where![]()
That was a close one cause if I couldn't Id have to take it all apart and do it again.
But yup good start and take your time!
