Plasti-dip question
coconutpete
I'd like to plasti-dip the center portion of my grill black.
This will obviously involve taping off the remainder of the grille.
I plan on doing 3 coats.
Do I need to remove the masking tape after each coat and then re-apply?
Or ...
Will it be OK to do 3 separate coats with 30 minutes of wait time in between and then remove the tape?
I want to avoid pulling off the plasti-dip in the locations where I actually want it to cover.
THanks.
You want to mask off and leave about an inch over the area you're spraying so you have something to peel off. I let my coats dry for about 6-7 minutes and put on another coat. The more coats you put, the easier it is to peel off!
My main concern was doing this and then having the plasti-dip peel off the area where I actually want it to cover when pulling the tape off.
It sounds like, based on your experience, that this will not be a problem.
Nope...Shouldn't be a problem at all!
I'm about to do the same, although I've worked with The Dip before. You can use a razor to finely cut the perimeter after you've sprayed to be certain nothing extra pulls off.
yeah I did 5 coats on the center grill piece, the more the better. even with 5 coats a rock or something managed to pierce it and make it look bad, or some A-hole picked at it.
Id do about 5-6 coats, waiting about 20 min between coats, just make sure you don't get carried away with your coats, build up a nice base by just dusting it on there and then add more and more as you go.
