Plasti-dip
happaflapp
So, I'm considering plasti-dipping my chrome parts on my 2007 SR5 4x4.
I want to black plasti-dip all the chrome parts. The grill, the emblems, the rear chrome placard.
I need tips, suggestions, and most off do I remove the emblems? Or do I just mask around them.
If there is thread somewhere. I apologize for the duplicate thread. Just post a link. And, I will move on.
Thanks.
no need to take anything of the car just use painters tape and newspapers to cover around the badges, be sure to shake the can a lot and make sure you give each coat enough time to dry like around a half hour if its warm out. Most of the excess should come off with the tape but for the spaces in between the letters use a toothpick or something similar.
Just mask a square around the emblems, you dont have to mask them off perfectly. I did remove the front because it just pops out. The unwanted plasti will peel off easily if you put enough coats on the area. Any accidental over spray can be taken off by a terry towel or something by simply rubbing. As stated above, search some on youtube or go to dipyourcar and you will find everything you need. I just did my wheels last week. Love plasti dip. Enjoy!
I just ordered the 4 wheel kit in charcoal grey for my silver 4th gen. Also just ordered a 2.5" lift to go along with it.
I've been considering the blackout look on my charcoal gray runner. My door handles are chrome and wonder if those should be blacked out as well.
Plasti-Dip Removal
How easy is to remove this stuff if you don't like the results or the way it looks?
Great info guys thanks.
So, is did you guys do some prep work to the chrome first? Scuff it up a bit? I will check out YouTube links for sure. But, I also trust you fellow TR4 owners experiences first.
And as far as peeling off excess plasti-dip. Does it not adhere to paint?
no need to prep anything but setting up the tape and newspapers...it adheres to anything you spray it on but it also comes off anything you spray it on
No... don't scuff up anything. Just clean the chrome with alcohol and use cotton swabs to clean the edges and in between. Having it clean just helps the PlastiDip adhere better. Once you get a corner up, you'll be surprised by how easily it peels off and leaves no residue of any kind!
Great! Thanks again.
The TR4 community is great! You guys don't flame. And, are very helpful. I appreciate it.
I wish I could connect with someone in Ohio and do some offroading around here (what little trails we have left).
I wouldn't take any of the emblems off, except for the front one just because it pops off from the backside of the grill. When you tape a square around the emblems, be sure to give yourself about an inch or so in order to give yourself a tab to work with when peeling the excess.Don't tape right up next to the badge because when you go to remove the tape, it will peel off the plasti-dip with it. Then use a toothpick to remove the dip inside the letters. Also, make sure you spray all the way onto the tape so it will peel off easily and not speckle. If you-re doing your grill, I wouldn't recommend taking it off because you can easily break the latch, and its just easier to do it with the grill on. The youtube page is extremely helpful for tips. I've done all the chrome on mine so far.
New to posting to this site. Anyone have defects (bubbling under the paint on their wheels) before dipping? It seems the previous owner didn't take great care of them and there are a handful of spots like this on the set. FYI, probably looks worse than it is due to the dirt/salt currently on them. Just wondering how it might turn out. Thinking about dipping my wheels but was wondering if the coating covers up defects at all or if it make them more pronounced. Also, anyone done the gunmetal grey on a Shadow Mica 4Runner? Was thinking of try that out. I've got the 6 spoke wheels on a 2006 sport.
I know the sr5 rims on my 04 were repaired by a dealership from the previous owner's request. I dont know that there was a recall for paint bubbling/peeling, but it seemed like many had issues with it happening. Again, this was the sr5 rims, not sure about sport rims but it could be the same.
I still haven't done mine yet. I hesitated on doing the rims. Not sure I like the blacked out look as far as rims go on a stock T4R. But, the rest of the chrome is as good as plasti-dipped come spring.
