Please Help me
Supertom1969
I have a 1990 T4R I bought from a friend that was running but running like crap. Turned out the engine only had about 25 lbs. of compression. So, I put a new long block in it. ie: Block, crank, pistons, heads, cams, etc. Once I got it back together it cranked and ran fine. Drove it home from where I was working on it. about a week later I drove it to work and all was good. I left work that evening and on the way home I stopped at a stop sign and started to take off but it would die everytime I pushed the gas. and it continues to do it now. It is only the ffirst touch of the gas, once I push it harder it will stay running, but if you try to take off normally it will die. It is also running a little rich. I don't know what the problem could be. I assume it has to be fuel and air but don't know where to start to look.
Thanks for any and all help.
Tommy B.
Dexterforme
