plug and play amp and subwoofer finally here?
vermontmike
Trail Grid Pro has a 5 channel amp and subwoofer that mates to the stock head unit to 2023. Pre wired and plug and play to stock head units. Wonder if anyone has seen this before? thoughts?
KICKER PLUG & PLAY DOWN-FIRING SUBWOOFER & 5-CHANNEL AMPLIFIER KIT | '03 - '23 4RUNNER
Kicker Shop
Trail Grid Pro
Kicker Shop
Trail Grid Pro
few months ago I asked cliff about a prewired amp kit and he did mention it was in the works. Curious to see if he would sell just the wiring kit without the amp, I'd prefer the kicker key 200.4 amp.
Can build the same harness with a Metra 70-1761 and a 71-1761 harnesses (~$20 each) and 10' of speedwire. Add any amp that accepts line level inputs. Tacotunes has this same patch harness for sale, albeit not as nicely wrapped.
I was considering this and doing some soldering with the speed wire. I retrofitted the 2022 head unit into a 17.
Amazon.com
OEM AP owner here. Have had it for two years now, still very happy with it.
I bought mine in June 2019 as a single sub system. Eventually I upgraded to the dual sub in April 2022. Long story short they were supposed to let me know the upgrade was available but never did. Otherwise I love it and they personally helped out when I had issues since I'm local.
I do wish I had more bass.
I used this 6 years ago and ran my own RCA's, power and ground and amp and it worked great with the stock HU :pop2:
good reviews of it, compact size under a seat, no remote wire or rca cables.
Amp kit, speed wire, harness (not sure which route to take ), amp
That connector is for a Entune 3.0 unit where all speaker leads are on one connector. The Entune 2.0 units have the front speaker leads in the main connector and the rear speaker leads on a smaller connector. For 2020 or older units you have to do a full harness replacement to add a amp.
correct....
i picked up a transplant hanress for the 2022 HU from here
AutoHarnessHouse - Custom Car Stereo Wiring Kits
thoughts on best route to install an amp ....harness etc?
I do with I had more bass.
Yeah we got ours with the dual sub setup. Agreed that we wish we had a bit more but for what it is, it's great.
Update
correct....
Any update on how the install went with the autohaus custom harness and a year's use of the kicker key 200.4 on the stock entune 3.0 HU. Where did you end up mounting the amp. I'm looking to do the same on my 2021. Any tips would be greatly appreciated.
Thanks in advance.
Thanks in advance.
I never did the kicker key amp project but it would go under the passenger or driver seat. You would need to run speed wire to and from the HU to the amp.
The autohaus harness works fine its a plug n play adapter. Only issue i had was one of the pins came loose and I reached out to support to find its location.
albertpeter156
