Plug and Play Rear Camera Override Dongle
Sorry for my stupidity. The instructions on the site don't go past radio removal. But what's the long wire that hangs off the 2 connectors? Whats the benefit of having the rear view camera outside of reverse?
Sorry if it was listed and I missed it.. 2016 trail. Which 28 pin dongle do I get? The site list 2 different ones, both being 28 pins.
One is for multiple video sources, and is for if you want to run additional cameras. This one isn't available yet. I believe he's waiting for test results.
The other is for just switching the Rear view camera on when you want it. This one is available.
The only other connector available is for the 2013 and prior models, and is a 5 pin connector.
With the older trucks i was unable to easily source the connectors for the harness and given the low interest with the older models i stopped looking.
Say it isn't so.............:sobbing:
Still would be interested (even at a higher price), '12 SR5 w/NAV non JBL
Also, can someone give me the idiot's guide to wire the switch? The dongle plug and play seems easy enough but where do I hook in the power wires?
Just wire the two wires to any terminals on a single pole switch. Also yes according to the Factory wiring diagram it should plug into your JBL unit.
Just got my dongle today, and spent this amazing afternoon installing it.
I did hit a hiccup, the first time I put everything all together it didn't work. However after going through everything and checking connections it works.
My only quip is that the dongle connecter didn't "click" in as firmly as I would have hoped. But...it works!!
Thank you for creating this easy to install dongle!
In goes the dongle!
And it works! Now I just need to wait for an Air On Board switch to arrive. Using a Home Depot one for now.
Video:
https://vimeo.com/159654586
In goes the dongle!
Video:
Awesome, really happy to see this working for you. Thanks for posting up the report. The female end can be a little tight to push into the nav unit it but it will go and fit. It's the pins connection that are snug, not the actual connector.
Thanks again!
In goes the dongle!
Video:
[MENTION=119176]415T4R[/MENTION],
Thanks for posting this....looks great!
[MENTION=129513]bjohnston115[/MENTION],
I don't think I've read it anyplace, but, there is nothing to prevent this mod from working when in Drive or any other gear as far as that's concerned?
[MENTION=103267]Saker[/MENTION]
Nothing prevents the use of this. It will work whenever the truck is on regardless of gear or anything else.
[MENTION=129513]bjohnston115[/MENTION] ,
I didn't think so, just wanted to make sure.
Thanks for making these!
In goes the dongle!
Video:
What are those 2 wires you are holding together?
charlesz
