Plug help.
Doc2012
Senior Member
I'm in a rush. Hence why I haven't looked it up, and I don't have a computer right now to look it up.
This little guy, behind the dash. Grey plug. Where does he go?
I can't remember, and can't find the spot on the heater core or anywhere else to plug him into.
I'd start checking and see what doesn't work. Looks more like a stereo harness. Do you have power antenna?
Does not look like a stereo plug. Power antenna out is also in the stereo plug so not that even. Do you have digital climate control?
Can you see a five-digit number embossed on it? It would make it much faster to look up.
EDIT: Never mind, it's a number 11686. I don't see it used in 2002, what year is yours? Please give year when asking electrical questions, always.
'99. Sorry Durk. Thought it was in my sig.
I do have digital, but it's not that. That's two white plugs.
Sorry, Doc. It's not a 11686. I can't find a match for that plug. It might not be factory. If you can find a number on the housing, I can try looking that up.
Doc, check the top left corner of the center junction box. I think that't it! Plug 3A.
See p. 26 at link:
http://tacoma.site40.net/4Runner_96.../ewdsourc/2002/024runne/relayloc/relayloc.pdf
Not it Durk.
I have that one; and a small two pin one that I can't seem to find a home for.
Heat, everything works fine.
I think the two pin is for the cig light surround, but this grey one is killing me.
Antenna relay maybe?
Here's the small one. Definitely a light of some sort. Either ashtray or cig lighter.
And the grey one in the bundle.
Yeah, I can't find a match in my EWD/Wire Harness Manual. A bunch of 8 pins that are close, but not exact. I have a '99, I'll take a look later and see if I can find it. Did you check for a number embossed on the other side? That would help...a lot.
I would say antenna relay plug. See this image of the relay:
Should be obvious if your power antenna doesnt work.
That could be it. The A23 antenna relay plug is grey and 3 over five pins, but the top did not look exactly right. The drawing shows the top as flat where there are those very shallow slots in the photo. Definitely worth a look. Those drawings can be off.
Well, here's my issue.
I got rid of the stock power antenna, and am using my CB as my radio antenna. Been gone for years.
I'm leaning toward the antenna relay. Everything works as it should, so I'm just going to leave it off until something doesn't work. Then I'll know. [emoji23]
