Portable Air Compressor Advice - VIAIR
Which VIAIR compressor do you recommend?
  • 300p
    Votes: 3 27.3%
  • 400p
    Votes: 5 45.5%
  • 440p
    Votes: 0 0.0%
  • 450p-a
    Votes: 2 18.2%
  • Other (please post)
    Votes: 1 9.1%
  • Total voters
    11
AirspeedX
I have spend HOURS searching which portable compressor to go with.
I planned on getting an on board air system with an ARB twin, but I can't justify the coin it's going to cost for the unit, plus a bracket (that I'd have to figure out how to make). So portable it is!
If I could, I'd buy the Puma 12v 1.5 gallon compressor. I just can't get one up here in Canada. :canada:
So I have decided to go with VIAIR (unless I hear otherwise).
Next thing is picking a model.
Main question - is an 'automatic' unit better than a standard unit? I'm still trying to wrap my head around this.
I know the Viair 450p-a has a 100% duty cycle but pumps out way less CFM's compared to the 440p with a 33% duty cycle. They are both on Amazon for the same price.
Or, for substantially less, I could go with a 400p.
Who here recommends what?
I just mounted a 450 behind the rear panel. Its quite and I can hardly even hear it running over road noise.
Have you considered CO2. If your only need for air is tires after off roading or the occassional air tool (as in an impact wrench to change a flat) it is not a bad alternative. CO2 tanks can be filled at most welding supply stores for under $20. Even when I was wheeling a couple of times a month I could still get a couple of months out of a fill up.
You can also take advantage of the portability to move to another vehicle or even run a nail gun for carpentry work around the house.
