Portable winch
Are you looking for a portable winch or this one specifically? You can make any winch portable pretty easy.
What makes it portable, the quick connect power leads?
Looks like the Amazon reviews are mixed.
Main thing will be thinking through how much you might actually use a winch and in what situations. I know that is hard to measure, but thinking about the trails, frequency, and area you live/explore. I always worry about going cheap on recovery gear, not to say this item is cheap.
If I were driving a Tacoma, I’d bite with a portable winch. It can live in the bed in a tool box. With the 4Runner, I’d hate to have that thing flying around the cabin in an accident.
Oh yeah, gotta be secured, but I think it's worth the trouble.
Heavy duty come along hasn't let me down yet! Go solo with no winch they think I'm crazy. Makes it more fun.
Cable on Portable Winch ?
Synthetic cable saves a lot of weight off the winch.
------- web stuff
Winch line 30.4 lbs (steel cable) 4.3 lbs (synthetic winch rope)
I knew someone would chime in. They aren't rubber, it's a tie down, and it's REALLY tight. Plus, it's pulled against the bins. In a serious enough wreck, it will be a minor concern.
JA50N, not this specific winch. Google searching & reading reviews led me to this one. With the minimal amount of use it would get, I can't justify the cost of a new bumper & the other added costs.
They make winch mounts that go in a hitch mount like on the rear of the 4runner. I'm not sure of a hidden hitch mount for the front of the 4runner though. Making quick disconnects for the power leads is pretty easy. Here is an example of what I did on the front of my GMC:
Untitled by JASON MCKIMMEY, on Flickr
I used an RV power plug I found on Amazon in line with the winch leads. That way if I want to remove the whole winch plate I just pull 2 1" pins from the CUCV shackle mounts and slide it off. I leave the electrical disconnected until I need to use the winch so I don't have any minute draw.
I’ve used a portable winch before, and it was pretty handy for various tasks. Recently, I tried out an electrical winch from Tecnotools, and it made a big difference. I used it to pull heavy equipment up a steep slope for a DIY project. The ease of setup and the power it provided was impressive. If you’re looking into portable winches, checking out some electric options might be worth it. They can really simplify lifting and moving heavy items. How are you planning to use yours?
tuṣṭāva
