Portal Axel?
RJLeagles2010
A long time ago while looking at the rear axel I wondered why someone had not found a way to move all that up and out of the way. Well I found the information and thought it might be worth sharing. Does anyone here have this on their T4R and if so pictures would be greatly appreciated. Dedicated off road rigs might be the only ones to benefit from this.
Here is a little information I dug up from Dynatrac.
"So what is the advantage of a portal axle? The gear reduction at the hub moves the axle center line up five inches for increased ground clearance. This is a dramatic change; the equivalent of switching from 35” to 44” tires on your vehicle. Additionally, the geared hub design provides a 1.5:1 gearing reduction through a massive 41 spline axle shaft designed specifically to account for increased torque loads. The nodular iron AIM portal gear boxes contain four 2.25 inch wide 8620 heat treated steel gears: a drive gear, two idler gears, and a gigantic driven gear that keeps the drive direction constant, making them a practical retrofit to traditional axle housings. By multiplying torque at the wheel, less torque is transferred through the driveshafts, transfer case, and other upstream drivetrain components. And a numerically higher gear ratio can also now be used, which results in a larger, stronger pinion gear.
The idea of using portal axles for more ground clearance is not new, however there have been a number of factors that have made them unfeasible… until now. In the past you had to overcome poorly functioning drum brakes, long pinions that result in short driveline lengths, excessive weight, and difficult to source foreign parts when trying to retrofit portal axles to your Jeep or 4x4. Dynatrac has worked closely with AIM and Mopar to address all of these issues (and more) with the introduction of their innovative new portal complete axle assemblies and sub-assembly components.
Realistically these new portal axles aren’t for everyone. They are not recommended for highway use, and the leverage of the portal design places additional stress on suspension mounting points and control arms. Electronic controls such as ESP and ABS cannot be retained with the portal boxes, as they can with Dynatrac’s traditional ProRock, Pro, and Trail Series axles. There is no provision for a standard parking brake; however a driveline brake at the transfer case can easily be added to address this issue. Final suspension design will be determined by many factors and it is crucial that the suspension design address the added torque and leverage of the portal system. The end user will need to design proper steering and a strong 4-link suspension. Therefore, it’s important that a qualified specialist with fabrication skills and a thorough knowledge of suspensions install it. In short, this isn’t a ‘turn-key’ assembly that fits any application. With the caveats out of the way, it becomes clear that if you require the absolute greatest ground clearance, with gear reduction to overcome the most severe, boulder-strewn trails and obstacles, there is no substitute for Dynatrac and Mopar axles equipped with AIM portal housings.
The portal wheel ends are currently available for king pin steering knuckles and full floating rear Dana 60, Dana 70, and AAM 14-Bolt applications. Dynatrac can provide the AIM portal housings on their proprietary ProRock and Pro-series axle assemblies with suspension brackets for a wide variety of vehicle applications" (Dynatrac - Confidence to Explore®).
Portals are sweet, most common are unimog units that have been adapted to fit normal bolt patterns and disk brakes. Pricey, but very cool.
Portals are sweet but having a ifs truck I don't see the point. Sas guys maybe, but the sas is a project on its own, now throw the cost of portals on top.
hummers(the original not the h2 and h3 gayshit) have portal axles and IFS/IRS... its cool put impractical and heavy and $$$. not to mention the power loss with them. if you has the $$$ to put portal axles in your 4runner they why the heck are you tinkering with a 4runner, there are much better things to use for that, like a truggy or buggy...
Awhile back i had seen a build on pirate where they guy put portal axles under a fj80 it was sooooo bad ass!
not everyone WANTS a truggy or buggy, but if you have that kind of cash, it would be a "one of a kind"
I also remember a FJ80 with portals, that made me research them, and WOOW way to much for my blood, not to mentions, the parts are not that easy to find, there was a company in southern Co. that specialized in portal/unimog axles, not sure if they are still in business.
ladies allow me to introduce you to 4mogger
4runner026.jpg~original
happy hunting 40" tires on 2nd gen! - YotaTech Forums
Volvo C303 is the only application i know of that had portals, I know some defender guys have done the portal swap, but the problem is how expensive those C303 axles have become which really cut back the amount of people that did the portal swap. And who wants to cut up a cool C303 to put the axles on an ugly LC, or modify a 4Runner that much to fit them?
Good time, from Russia. We also make portal axles. Today, the exchange rate, lets not expensive to buy, only 2500 - 3000 dollorov, per set of 4 pieces, ready to fully self-installation.
EnviroHokie
