Power Antenna Problems
sc4runner13
I can not figure out the problem with my stereo. It is an aftermarket CD player. It comes on when it wants not when I want it to. I can hear a noise under the dash when it is coming on and off b/c sometimes it comes on and goes right back off. I have checked the fuses. Help!
When this happens the power antenna does not come up when I turn on the truck. When the radio does decide to work it seems that it is b/c the antenna gets power and will raise and the radio works fine. But then by itself it cuts off and the antenna retracts.
i would think when the radio is off it should be off. you need to pull the fuse to it completely
for now , it could very well cause you a world of probs like a fire.
my old 93 truck has something like this going on too. with radio off i hear static coming from my dash as im driving . now i dont have power antenna on that old truck and radio does work. might be time for new radios for both of us? and maybe antennas also :D
pull that radio fuse out and chant with me . no fire no fire no fire :lol:
fuse unlikely?
Interesting. I'm thinking this through out loud: A fuse alone would not power up the unit/antennae. The fuse COULD compete an already open circuit if it exists and there is a problem also with the fuse holder. Unlikely though if you ask me. Sounds like there could be a short with the power on circuit most likely in the radio itself? And I assume the antennae runs from a remote power on wire. is the unit hard wired independent of the factory harness or is the factory harness/plug used? It seems to me that problems up under the dash are common, I know I have an issue with heating a/c harness. I would try wiring it direct and see if that helps.
Turned out to be loose fuse after all. I had already taken the fuse out and checked it. But the truck was off. I did it with the ignition on it and the radio came on when I pushed really hard and has stayed on since.
ian2328
