Power door locks GONE. Into the ether....
madetomeasure
Well...
(I searched)
I have a '97 Limited (with VIP, fyi)
The power doors locks decided to stop functioning completely, windows and ALL other accessories are working fine.
Key in the door doesn't activate the single door/all door feature
interior switches do not activate them
Fob doesn't activate them.
It's obviously not the actuators as all quit at once.
I pulled the fuse panel but none are specific to locks.... and as stated all other acc. work as they should
Any help or previous threads anyone can point me towards?
I would look into the integration relay.
This is definitely the problem. I just fixed my 96 4Runners power door locks by replacing this relay & the whole fuse block. With mine I found that it shorted out internally and melted a ground wire coming out the back of fuse block. Almost fried my whole body harness. Luckily I could just run a new ground wire & replace the fuse block & integration relay and problem solved, all my door locks work again.
