Power steering system diagrams?
danielevioli
1992 3vze, 4wd
I recently picked up a chilton's manual from the library, but there seem to be no diagrams of the power steering. All the lines, the pump, etc. Anyone know where I can see how all this stuff is routed?
So which component is this? It doesn't appear in the diagram...
You did read the attached section of the FSM, right? BLEEDING OF REAR–WHEEL ANTI–LOCK BRAKE SYSTEM
HINT: Whenever PS hoses or PS pressure tube are dis– connected or actuator is removed from the vehicle, the Rear–Wheel Anti–Lock Brake System should be bled in the following procedure. At the other times, use the conventional procedure.
From the picture you posted you have a good amount of corrosion and I'm guessing you had an issue with the battery at some time. Shop for replacement PS hoses on-line. The one from the pump to the actuator is in need of replacemnt.
Do you need the "Actuator Checker" or "SST" to properly do this procedure? Seems kinda excessive... is there a way around it?
