Power Windows Gen 3 HELP!!! :help:
Partridge1961
Folks I need your help. My driver's side door master switch apparently has developed a break in the area between the door and frame; the area with the greatest amount of flex. Does anyone have an idea of which color wires are associated with the window's function from the driver's door master switch? Help PLEASE????!!!! My wiring diagram is suspect at best!:sick::yield::yield::yield::wacko:help::help:
You should be able to match the color codes. No two wires have the same color in the master door wire harness.
What diagram do you have? And what year is your runner?
seltzernator
