Pro Comp 7069 16x8 - Will they fit and clear the Tundra brakes?
I'm almost positive you will rub when stuffed off-road and maybe even at full lock. I have 31.5" tires with a 3" lift and still rub when fully stuffed but not on the street. As far as the procomp wheels go they even say right on the website it has a large offset to clear large modern day calipers, but I don't have a definitive answer hopefully someone who has them can chime in!
I'm getting ready to pull the trigger on the Pro Comp 7069 16x8 wheels and plan on getting the Cooper STT Pro tires at 285/75r16.
https://www.4wheelparts.com/p/pro-c...tern-matte-black-7069-6883/_/R-BKBQ-7069-6883
Will these wheels clear the Tundra Brake Upgrade?
Will I rub with these tires (I've got a a 3in lift currently) ?
The Pro Comp 7069s 16x8 WILL clear the TBU just fine. I had them.
They will probably rub a bit on the pinch welds. If memory serves me, they are about a 4" BS wheel. If you had SPC UCAs, and set their setting for one of the more forward settings F or G, you'd probably clear just fine.
Pulled the trigger an got the Pro Comp 7069's with the Cooper STT Pro's.
Won't be upgrading the UCA's anytime soon, so I'll have to make sure to be careful till then. May need to fold in the pinch welds.
If I have vertical clearance issues, I'll be throwing on a 1" body lift.
Cool! Post up some pics when you get those bad boys on.
O you know I will !
Tires showed up yesterday, still waiting on wheels and lugs.
Hoping I can get them mounted up before xmas so I can go snow wheelin !
