Problem after timing belt
Mr.runner
2001 runner limited 3.4 98K. After timing belt change I went for a test drive and everyting looks good no problem. Same day after test drive I washed the engine and the next day I have static problem and no miles in odometer. I got the engine scaned and the code is coil #2. After coil #2 and cable change I have the same problem. Help this is my wifes SUV and she loves it
Your problem sounds like it has nothing to do with the timing belt replacement. Sounds like you shorted something out when you washed it. Maybe all that's needed is to dry and clean all the electrical connections.
seltzernator
